Greetings, first time visitor. I have always been attracted to shiny things so I guess it was just a matter of time before I got hooked on watches.
I am bringing a Ball Fireman 40mm NM2098C back to life. It is missing the screw down crown. Can anyone tell me what size crown Ball was using in this case?
Thanks a lot
Thank you for your introduction and welcome to this friendly forum.
You need to measure the fitting on the case and the size of the thread on the stem. All good watch parts suppliers should be able to help you out with a replacement.
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
