Hello,
I have another question:
How do I thread or attach the hairspring to the regulator (?) on the balance cock? (It's from a BFG 866)
See attached image and thanks in advance for any help.
gina
The end of the HS is normally attached via HS pin (very small brass tampered pin). The easiest way I have found is (if the HS is already installed onto the balance) is to fit the balance and balance bridge into the watch plate. Once the balance & bridge are fitted you can then swivel (Obviously the pallet folk & assembly must have been removed) the HS around and carefully thread the HS end through the stud hole & pin it.
You should be able to turn the thick part to open it. Fix the complete balance, making sure the hair spring is between the regulator and then close it. Just be careful when closing the hairspring is out of the way, you do not want to pinch it.
I've attached a lesson I wrote on the BFG 866, which includes refitting the hairspring. Just make sure to turn the boot 90 degrees with a screwdriver of appropriate size to enable the hairspring to sit between the boot and curb pin. Fit the stud, then close the boot.
If your hairspring needs refitting to the stud, you'll need a small brass pin shown in the photo. I prefer to fit the HS when it is clear of the balnace
Lesson 15. The Baumgartner 866 continued.ppt
Edited by Jon
I should post on the walk through section what I've written on the BFG, which are about four lessons I think
Hi  Jon   I think that a post of that nature would be beneficial for may users. Look forward to seeing it. If it was in PDF format it could be down loaded and kept as a reference to many of the Beginners.
I've just uploaded the first instalment of the BFG 866 in the 'Walk through' section and I've got a few more to post when I've got time within the next few days.
Now I see! I didn't even know there was a boot that turned. So, I get what I'm supposed to do, but after I fit the stud what is the best way to get the hairspring to slide in between the pin and the stud? I've tried laying the hairspring so that it lines up with the stud and in between the boot and pin before fitting the stud, but it's a game of cat and mouse. I am patient and stubborn: two traits required for this hobby.
Also, which tool is best used for laying the hairspring between the pin and boot? Tweezers? I barely look at a hairspring and it bends.
It is easier if you increase the distance between the regulator and the stud. The disadvantage is, you have a lot of readjusting to do later.
Use the sharpened oiler (clean it thoroughly first) or the tips of your very finest tweezers to gently lift and ease the spring into position. You only need to tickle the spring from one side, so it can slip over the tool and move away if it wants to. Eventually you will find the right move, and it will seem obvious. If you try to grip the spring with tweezers and lift it you risk forcing it and deforming it, either with too much pressure, or too much movement.
Sometimes it is easier to make sure the hairspring is sitting between the boot and curb pin before fixing the stud in place. It's just practice... as you said 'cat and mouse'
If the hairspring is not concentric or part of it is out of shape, the hairspring when sitting between the boot and curb pin will push against one of them when the stud is fixed in place, thus not allowing a small movement of the hairspring to 'bounce' between boot and pin whilst the balance is spinning. This in turn technically shortens the hairspring because of the lack of free movement and the watch will run fast because of the shorter hairspring.
  • 2 years later...
Hi Everyone :),
I'm a newbie here and was wondering if the lesson 15 is still available anywhere? I've only just started  my journey and this forum has been a really good source of information and although the movement I'm working on is a Brac 502, I thought I might ask the group as I'm sure this would be helpful. Thanks
Hi Jeff,
I just downloaded it from the attachment in the message above. It is a PowerPoint presentation.
Does this show the proper method? I just mangled a perfectly good spring and don't want to kill the replacement that's coming. I'm practicing on my damaged one and it does not want to go up in that hole either 🙂 Its going to be a battle for sure
    • Thank you @Mark. I only became a Patreon subscriber 5 or 6 months ago, but I draw so much value here. If you come up with future contribution or support opportunities, I will be on board.
