The infamous Seiko 5606 day-date corrector wheel rocker - sorted, I made a new wheel
I bought a Seiko LordMatic cal 5606A and noticed the quick change day-date wasn't working.
A bit of Googling found out that they rarely do on these movements, due to the plastic wheel on the day-date corrector wheel rocker breaking (see pic).
As it's such a common problem, I thought I was lucky to find a NOS one on ebay.
Unfortunately the plastic wheel on that was already broken - I've since read that this is common on NOS items, the plastic ages and breaks.
The one I have at the moment is spare time, so I found a bit of brass from an old pocket watch, got my finest file (#6), drilled a 1 mm hole,  and started filing ...
It took a while ....
But got something close :
I think it's OK as a first effort at making a part.
It's not perfect, far from it, but doesn't need to be as it only needs to push the day-date wheels over.
What I found was :
 I couldn't have done it without my stereo microscope
Although a #6 file seems very fine, it's way too course to finish the part. I believe you can get #8 and #10 cuts.
I sharpened the end of an old screwdriver to use like a chisel. I finished with some 3000 grit paper, but it's not easy to fix a small enough piece to use.
I haven't stripped the movement yet, so don't know if the part works - can't see why it shouldn't
Mike
Edited by mikepilk
  • Like 6
Just now, mikepilk said:
Hi @rogart63, who /what is VTA?
It's a company in Australia that sells parts for Seiko. His name is Adrian Sellick and is a watchmaker from down under. VTA stands for Vintage Time AU. Don't know if he sells on Ebay . But did before under the name halfoeight. Have the nice forum Wristsushi also.
  • Thanks 2
Yes I also bought the star from VTA, the advantage is that he make it metalic so it's a permanent fix. I think they are out of stock though.
If your star works then it is a perfect fix, and also permanent I think. Very good job Mike.
Here's a video by Adrian showing how to install it:
It could be made a little better but works very good . heard of some that has problems when the movement have a day disc. But has worked fine for me . Still have one of them left. But some small tabs up would make it perfect.
Edited by rogart63
  • 1 year later...
I made one, thanks to finding Mike’s post (thanks Mike!).
I made it from 0.3mm brass (an old dial) doing exactly as Mike did above, only I carved it out with X-acto knives instead of files. It went very quickly as brass carves like wood at that scale, but I couldn’t have done it without my stereo scope.
Mine would not engage the day disk, so I carefully bent the teeth up slightly under the scope while clamping the gear in a set of flat needle nose pliers so it would not deform.
The carving, including test fitting and  finishing touches, took about an hour. The teeth engage both day and date portions correctly and the star wheel slips properly when resistance is met. Very easy job. 😉
Edited by PinLeverPete
I used a slightly thicker piece of brass as I noticed the teeth where higher than the central circular part - hence you needing to bend them up. It wasn't easy reducing the depth of the central circular part. I used an old screwdriver as a scraper.
Initially I made the teeth too wide, which caused jamming, but once filed down worked fine.
I found marking the part out difficult - all tools seem so big and clumsy on that scale.
  • 7 months later...
After seeing this I was inspired to make myself a 5606 star wheel. Made from 0.7mm brass plate, sanded down to 0.5mm with 600 grit paper as last step. Marked out with a sharp sewing needle in a pin vice. Shaped with a Dremel cut off type abrasive disc (was approx 0.8mm thick). Hole was 1mm and then carefully broached to be a friction fit on the gear wheel. After getting the flat shape correct I transferred the star to a cocktail stick and then brought the abrasive disc down vertically inside of the 4 corners (to make the raised teeth and lower central part). Finished the central lower part using a sharpened screwdriver as a chisel. Finished with fine abrasive paper 2000 grit. Took me three attempts to get something I was happy with (lost one when the Dremel spun it off the cocktail stick never to be seen again). Star wheel works really well.
9 hours ago, Michael1962 said:
Kudos to all of your effort gents. Well done.
Would the wheel measure about 3mm across the points?
Small piece to make. 👍
Original is 2.5mm across the diagonal, 1.8mm square, although mine did end up a touch bigger, 2.7mm diagonal. Any bigger than that and it will bind and not rotate.
Hey guys,
I am new here and new to fiddling with watch parts. I tried to 3D print the part out. Did not get anywhere. My Photon S just does not have the resolution to make parts that small. I then thought I have this other material. Bought this for another project a few years back. What do you think? Another question, Is there anyway for me to test out if this work without buying a staking set? The lordmatic was listed as junk and $40 so I was wondering if there is anyway to muddle my way through and get it working?
  • 1 year later...
 Quick date set mech on 5605 and most other watches is flawed . You have  a free wheel  ie;  not in sync with teeth on  date plate so there is no gurantee they engage pefectly every moment you activate the quick set device, therefor you have the choice of either teeth to brake ,
Choice one , the teeth on the corector ,
Choice two , the teeth on date wheel.
To make both out of metals simply means one is unaware he is making  teeth on both vounerable to breakage.  Its not perfect as is called in above posts.
Good design would be to have the corrector and date disc in constant contact  " in sync "  and just activate-deactivate it somewhere in the set mech.
When a piece breaks in a watch, you replace it with new.
Thats not the case with airborn delivery vehicles, where if a part misfunctions up there, the designer team on the ground is unlikely to live to tell the story of the explosion to others.
My advice would be to make a plastic corrector like Seiko designers did, so to save the date disc.
  • 7 months later...
What I found was :
Mike
How do you separate the axle from the bridge?
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
