Hi all,
I took a punt at the last minute on this 23 Jewel Russian Luch Sekonda last week on the Bay, I took a chance on it because I thought it was one of the scarcer Blue Dials that had been put in a gold plated case, but did not have enough time to read the listing until after :biggrin: when the listing stated a Black Dial I was slightly disapointed. Anyway after reminding myself to always read a listing before bidding, I looked forward to receiving the watch, so I could get to work on it. I thought I would share some photos of the process with you all..
It did not turn out too bad at all
Best Wishes to you all
Darren
Many Thanks Guys
Judging by the 1st photo I was hoping it was the crystal that was damaged and not the dial, I was quite relieved when I received and checked it and found the dial to be in great condition
another one saved from scrapheap...
Many Thanks Guys
Best Wishes
Darren
That's a very tidy job and a fantastic restoration.
I love the apparent excess of intermediate wheels between the crown wheel and the ratchet wheel and wonder what the rationale behind it is. I have come across it on other Soviet watches (most recently a Slava 2414) which have had two mainsprings and barrels, but this one seems to have only one. The arrangement doesn't even change the direction of rotation of the crown relative to the ratchet wheel.
A top notch result anyway.
Hi Marc
Many Thanks..
The arrangement of the intermediate wheels has to follow that order as well, they don't fit any other way
there is also two extra wheels under the train bridge thus making 5 wheels in total, the Soviets have some really interesting
movements with some great design features yet also some of their ideas for their movements seen to be based on a Fri afternoon thought :)
I am just cleaning another one now and have another following in the post, should be here next week... :P
Many Thanks and Best Wishes
Darren
  • 4 weeks later...
Very nice work! When I saw your first photo, I too was worried about what looked like dial damage.
Regarding the extra wheels, perhaps the Ministry of Watch Wheels produced too many wheels, so the Ministry of Watch Movements had to design a movement to use them all. Such is Soviet management. :)
Edited by svorkoetter
Hi Svorkoetter,
Many Thanks for your post...
It was a complete gamble with only a minute to decide, at best I would come out with a great watch at worst some spares for a different restoration fortunately it was the former...
These movements are pretty good to work on but I wonder why Luch opted for the Tri-shock shock system for the 23 jewel rather than the inca in its 19 jewel cousin as well as a fixed stud carrier rather than movable. I think this model could pre-date the 19 jewel Raketa...
Best wishes
Darren
2 barrels usually give increased power reserve or more leveled torque or flexibility in components arrangement or combination of thereof. In case of Slava, it is components arrangement. (And, maybe torque, but i don't know about that in Slava's case.) Certainly not power reserve: Slava movements have 31-40 hour, depending on movement.
The arrangement of the intermediate wheels has to follow that order as well, they don't fit any other way...
Yes, they don't. 2209 was Soviet thin watch. From ranfft.de: "With an intermediate wheel between minute pinion and a separate minute wheel the complete train is moved from the center to the periphery. And due to the indirect sweep second, there is also no second wheel in the center. Thus neither balance nor barrel is overlapped by any wheel, and the complete height is available for barrel and balance. The result is a rather low profile without reducing sturdiness or accuracy."
... but I wonder why Luch opted for the Tri-shock shock system for the 23 jewel rather than the inca in its 19 jewel cousin as well as a fixed stud carrier rather than movable. I think this model could pre-date the 19 jewel Raketa...
Mobile stud carrier was later development. (And different balance ring.) Your movement is pre 1983. They were made since 1961.
Can't comment on Tri-shock vs Incablock question. Or on relationship of Raketa and Luch.
Denis
That's a fantastic explanation Thanks very much for that Denis
I now know who to seek out if I have any questions/problems with Soviet made movements
My thanks and Best Wishes
Darren
    • Hi folks, I'm doing some homework on getting a watchmaker's lathe, and it's clear I have a lot to learn. But I know one goal: I want to be able to fabricate wheels, which would require an indexing capability. I know how to use large lathes- like, giant metal lathes- but my experience is a few decades old now (but you never forget the smell of the metal cutting oil). So I'm looking to learn anew, and have a goal to get to a point where I can fabricate some basic watch parts. I also have no specific timeframe and want to do this right, so I'll be patient and learn what I need to before spending the money. I know I'm not going to get anything for a pittance, but I'm also not really able to put together the scratch for a $5-$10k lathe. What's out there for a hobbyist that can either handle some fabrication out of the box or can be relatively easily made to do so? Thanks!
    • Hello and welcome to the WRT forum.   This usually points to broken balance pivot.  Though a watch in need of clean & lube can do the same. Easiest diag would be to  see if balance pivot doesn't stay in hole jewel of the setting, when you lift one side of balance rim with an oiler or gently with pair of tweezers. Another would be to detach balance complete from the cock and take a look at pivot under high maginfication.  Regs
    • Ahhh, yes.  I hadn’t thought of that.  I’ve serviced quite a few of these and the first time I didn’t realise it was a ships strike pattern!  Ha ha, confused me totally until I realised.
    • Hi Mike, I did, thanks. Found this clip that was really helpful:   It says Seth Thomas but it's actually the same Hermle I've been working on. I'd had it working correctly all along but hadn't noticed that the lever with the sprung end stops the hammer a bit short of the bell on the second ding at the end of the half-past sequence. If only I'd put the bell on when testing, rather than just looking at the hammer, my ears would have told me it was working,  even if my eyes didn't!
