Hi everyone, was super delighted to see how responsive this community is... I am resolving the 1st issue with my Slava watch and now I am confident I can get some help with my Molnya 3602
-I took it apart and noticed the balance spring is a little uneven and does not go back and forth... I took the bridge off (one screw) took out the balance wheel and spring attached but did not see anything wrong, out it back and the same issue pessimists.
I need help understanding if the balance wheel is properly installed and / or needs replacement to get the mechanism to function.
checked all other parts and main spring is good. Would help if I can also find the front crystal/glass and an authentic face.
When you rebuilt the movement did you put each wheel in one at a time then the top plate to see if each wheel turned freely when a blower was puffed on them? Once each wheel is in place and runs freely then put the next wheel in the train and do the same again ie centre wheel, then centre wheel and fourth wheel etc until you are sure the train runs freely.
its a long process but ensures the train is good and narrows down to where your problem sits. The balance. And escapement, if the problem is actually there. Test the train first ok.
The overcoil / terminal curve on your hair spring is way out of shape and doesn't appear to be between the regulator pins.
The overcoil should cross over the top of the body of the hair spring (arrow A) and pass between the regulator pins (arrow B).
Yours appears to go around the outside of the body of the hair spring rather like the terminal curve on a flat h/s and completely misses the regulator.
Edited by Marc
added pic
17 hours ago, Klassiker said:
What exactly is happening with the balance wheel? Is it not swinging at all, swinging normally at first but coming to a rapid stop, or swinging erratically?
It swinging normally at first but coming to a stop after a couple of swings...
I tinkered with the spring and the balance started to work but only when I hold the watch at ~30 degree angle... if I lay it flat it stops. Also I noticed that the balance wheel has play, is this normal and by how much?
You have a broken pivot. It's a common breakage on these older movements without shock protection.
10 hours ago, AlexeiJ1 said:
You probably have a broken balance staff as well.
Inspect the pivots with a 20x loupe. They should be roughly same length on both sides.
May be easier to fit a new wheel than to re-staff it.
Thanks, I will be replacing the entire balance unit, any idea where to source the parts ?
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
