Hello! Finally got a 7750 to work on, all has gone without a hitch, and now about to do the one bit I'm not really looking forward to, fitting the hands. I have a 7750 holder with screw-in inserts to support the jewels, the minute register jewel seems well supported, but none of the inserts fit inside the automatic plate hole for the centre jewel. Pictured below jewel with the holder insert. Could someone confirm how I'm supposed to support it please? Thank you!
Concur with hector, A kink or twist in hairspring, exactly at regulator gap can cause this, so move the regulator arm to exposed hairspring ( H/S ) there and check with high maginfication. Regulator slot not wide enough or nearly/ fully closed, the gap just limits breathing of H/S. Damaged regulator gap, a close up high maginfication of the gap helps. Is regulator arm fitted fully in the setting groove? Good luck.
