I have an AS1187 movement that will not continue running when wound. It passes the wheel train 'blow' test both ways with no binding, and the pallet fork and escape wheel do what they should when moved with some power in the mainspring. However, when I set the movement down it ceases running; either after a few seconds or a good few minutes. The slightest touch has it running; it 'wants to go.' I have substituted another mainspring but that makes no difference. Should I investigate back from the balance, or is there something more obvious that I am missing? Any ideas would be welcome, thanks.
Hi  I should investigate the balance for cracked Jewels, bent/broken/worn pivots , The balance spring for concentricity and flatness also is the spring running in the regulator evenly (not laying on the posts).  At a last resort just fit the balance with no fork/pallet and give it a slight puff with the blower and check for freedom of movement.
  • Thanks 2
Remove the canon pinion to eliminate the minute train.
 Did you lube pallet jewels?
Check side and end shakes on staff, fork arbour and escape wheel.  Check if escape wheel wobbles and possible misalignment of or damaged pallet and fork jewels.
Make  sure the impulse pin is about or in beat.
Supplement power manually to the barrel or a gear of main train.
  Check its running in all positions.
Good luck.
  • Thanks 2
Yes escapement is the prime suspect. Guard pin or the fork horn rubbing on roller can grind the running to a hault. I the check out with watchaeasol list. There is also a chance of guard pin or fork hoen rubbing on the roller. So many possibilities there.
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
