Hi all,
My Longines VHP arrived yesterday and it is keeping very good time. I watched the date change today and was surprised that it took about 2 hours. Is that typical?
Thanks,
henryr
Depending on which movement you have , it have had a couple throughout the years it might take different time for the date change , mostly the process starts at 11pm and finish at 12pm.
My memory might be wrong but think there is a ETA 252.611(others 255.561, 255.563)  in yours so here is a manual for it. Only says the change is at 12pm not when it begins.
https://shopb2b.eta.ch/technical_documents/index/pdf/id/1713/
Thanks, I also have that pdf file. However  it seems more like a document for a watch repair person. I am hoping to find something more like a users guide with pics of the crown's three position and what they do.
Thank you. The manual has info I was looking for. I my watch had a three position crown but when I pulled out the crown there were only two positions and I thought maybe the watch was damaged. After reading the manual I believe the first position is the crown pushed all the way in, which is the running position. Hope I got that right.
So typically all the way  in is the normal running position of any watch. Pulling it all the way out the extreme usually sets the hands. Then some watches will have the middle position for rapid calendar setting.
Then how fast the calendar change depends upon the movements. This ranges from instantaneous where the thing just snaps. Others take lots of hours.
Thanks again. The 1680 section says it has a perpetual calendar but I think mine does not have a perp calendar. More research ahead.
Edited by henryr
I searched Omega caliber 1680 and found that it has ETA252.511. That explains the perp calendar. It seems  impossible to find info for the 255.563 but I'l keep looking.
1 hour ago, HSL said:
The Crown layout and modes.
255.563 = SA 1538 = fig 1.
So you should look for the Omega 1538...
Figure 1 in the first page in the manual.
And Page 11-12  .
omega-sa-1538-user-manual.pdf
Edited by HSL
Thanks for the info. Since I got the watch the date has been changing at 12 PM. So yesterday,  based on posts I've read, it needs to set for AM. I pulled out the crown to the 2nd position and wound hour hand around to equal 12 hours. The date increased by one day and I thought it was properly set. However, today it changed at 12 PM again. What am I doing wrong.
Another thought I had is, after the date change is completed, I could pull the crown out to the 3rd position to stop the watch and push it back in after 12 hours had passed. Is there any downside doing that?
Thanks,
henryr
So this is what happens when you don't pay attention in this case it was me not paying attention? It sunk in the word perpetual and quartz that changes everything. These watches or some of them can be incredibly hard to set. If it was a mechanical watch I would tell you to pull crown all the way out run the hands around verify the date only changes every other 12 hours figure out where a.m. p.m. is your good to go. But this is a perpetual calendar watch quartz which means electronic setting. This can get very very complicated. Then it would be helpful if there's numbers on the back of the watch in case there's variations. Because if there is only one version of the watch you can go to their website and they have the setting instructions sort of so I have a link it looks pretty simple.
Notice in the video the reference to the watch was set in Switzerland? Then it tells you how to change the time for wherever you are and it looks really simple? This is fine unless somebody has changed the battery then things get really really interesting so we will hope that that hasn't happened.
https://www.longines.com/watches/conquest/l3-716-4-76-6
My watch is the L237.2 with ETA 255.563. It does not have a perpetual calendar. I think the perp calendar model came out around 1996 and had an ETA 252.611 movement and the caliber was L546.2.
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
    • I bought an old Bergeon 5555. The bottom of the tank was full of petrified salts, which also corroded the metal parts a bit. I would use just distilled water.
    • Can anyone help me identify this watch/pendant. It was inherited by me from my grandmother and I am unsure as to what it is. It's a watch/necklace with a blue face with the inscription "INGERSOLL" and "Swiss Made". Have tried looking online but to no avail. If anyone knows a make/model or knows where I might be able to find out about it, that would be very helpful.
