Just would like to know what others use to clean watch crystals, outside isn’t a problem but when reassembling a watch what to use on the inside.
7 hours ago, Redwood said:
So if the inside of the crystal becomes heavily soiled with years of grim what chemical would you clean it with
The the most efficient "chemical" I've come across for all sorts of grime is warm/hot water and a good detergent (and a toothbrush). Let it soak for some time first.
If it is a plastic crystal you may find this link useful: http://forums.watchuseek.com/f10/beginners-exterior-watch-detailing-videos-3983474.html#post37998658 If plastic you can sandpaper the outside as well as the inside, but in most cases Polywatch will be enough for the inside.
Edited by VWatchie
Be very careful to fully rinse the crystal if you have to resort to polishing the inside. It’s not usually necessary.
I use Greiner soap in my ultrasonic, but washing up liquid would be just as good since it doesn’t need to be ammoniated.
I am a bit unconventional in my way of doing things and I'm always looking for a product that I can 're-purpose'. 3M Auto Rubbing Compound is a 3k grit compound that is used to remove fog from auto headlights, but it is an excellent product for watch crystals. I've used it for a long time and never use anything else. Buy one bottle for about $12.00US and it'll last a lifetime.
I just wanted to know what others use on the inside, i use window cleaner with a cotton bud and dry off with a lint free cloth.
As for  acrylic I use Dialux yellow with a soft mop after the pre sanding
good video, the guy was very passionate although I was cringing a few times
Just bought some
Sent from my GT-N5110 using Tapatalk
18 hours ago, jdrichard said:
Just bought some
I'll be interested in your impression of how it works. A small dot of compound and lite pressure with a cloth and with a bit of rubbing it'll look much better.
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
