I'm trying to swap out a rusted 2824. The dial curves down at the edges and seizes up the flat date wheel that came on the replacement movement. The dial feet barely comes through the other side and adding a spacer means no dial feet will come through the other side at all for the fasteners to bite into. The original date wheel had a sloped to it to get around this, but as it suffered rusting, reusing it is not an ideal option. Anyone know where I might find a sloped 2824 date wheel?
Hi there. from Jules Borel , ETA 2836-2  DATE DIAL, CURVED  02557.2836.B .You can put a 2836 date disk on a 2824 but cannot put a 2824 date disk on a 2836 .The 2824 date disk part number is 2556 and 2836 date disk part number is 2557.The 2836 one is more versatile of the two, being able to fit both movements, but on a 2824 it will not change instantly like the 2836. Hope this helps .Or you can send it of to dial restorer.Here is a link to the date disk http://cgi.julesborel.com/cgi-bin/matcgi2?ref=e[bHYJ
Edited by Graziano
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
    • I bought an old Bergeon 5555. The bottom of the tank was full of petrified salts, which also corroded the metal parts a bit. I would use just distilled water.
    • Can anyone help me identify this watch/pendant. It was inherited by me from my grandmother and I am unsure as to what it is. It's a watch/necklace with a blue face with the inscription "INGERSOLL" and "Swiss Made". Have tried looking online but to no avail. If anyone knows a make/model or knows where I might be able to find out about it, that would be very helpful.
