Hi All
I'm a beginner.  The second hand is just hitting the crystal in this AS 1916. The hands are straight.  I believe I'm using a high dome crystal.  That's what the label says, though I could have mixed it up with others.  The crystal in question is on the right and the dome appears higher than that of the Omega on the right.  The Omega has a second hand.
Below you can see that the second hand is ridding high on the post.  Should it??
Though, clearance over the minute hand is minimal.  So, it appears the second hand would impact the minute hand if it were any lower.
Do I need a higher high dome or is something else wrong?
Thank you
Charlie
Edited by Lc130
What is the hour hand clearance from the dial like? And did you press it all the way down so that it was flush with the top of the hour wheel?
I reseated all the hands.  Same problem.
The hour and minute hands are flush with the top of their posts.  The second had still sits very high.  The crystal was off the watch when I got it.  Could the second hand be wrong?
Very  often  second hands are bent down  towards  the end in order  to clear the crystal. Do you think you could  put a slight bend on the end of your second  hand that would allow it to clear  the minute hand and crystal? If not..you might want to think about s higher dome or shorter second  hand.
Edited by yankeedog
If it were mine, judging by what you’ve described, I’d press the seconds hand down a little further. If the tip-end of the seconds hand starts to touch the minute hand then adjust it gently in situ.
It looks like a high-dome crystal and I wouldn’t expect you to need a taller one.
There's very little clearance between the minute and second hand for a down bend.
Should the second hand be this high on the pinion?  I could press it down harder but I'm afraid to break something.  And, if it did go down it would hit the minute hand requiring a bend upward at the end for the second hand.
I suspect this is some basic error on my part that I'm not seeing.  Plz take a look at the pics.  I'll take care of that fiber:)
Thank you
Charlie
As I assumed.  This beginner doesn't have a trained eye yet.  The dial is resting on the crystal with a space between it and the case.  I didn't pick up on this.
The case doesn't have a ledge for the dial to rest on.
My case and dial are the same as shown here.  Though, mine doesn't say "Galaxie"  https://shop.watchsteez.com/products/elgin-galaxie-day-date-automatic
This is what I've got:
I'm missing something or I got parts from two watches??
Edited by Lc130
It’s quite common for the dial to rest directly on the crystal.
Does it rub at the centre or at the perimeter?
Perimeter.  I did push the second hand down so that the gap is almost gone.  The second hand now barely clears the minute hand.
And the hands are all flat.  All very strange.
Thank you for your help.
Charlie
What is the clearance like between the minute hand tip and the dial?
Sometimes when hand collets get worn, the hands will be able to seat at a slightly different angle which you may be able to vary when pressing the hands down.  But also, previous watchmakers may have adjusted the hands by pulling them upwards or pushing downwards to produce a slight bend.
It comes down to judgement, but sometimes you do need to make the decision to correct the straightness of the hands themselves. It’s very common to see centre seconds hands which have been modified in this way.
The clearance between minute hand and index markers is almost nil.  Same for second and minute hands.  There's no room for any more downward adjustment.  Could the crystal be wrong?
Your photo of the crystal does look like a high-dome to me. But those profiles do vary. Some curve more steeply at the edges which gives more clearance to the hand tips.
Is it a tension ring crystal? The photo in your link looked like an ATC crystal to me. I thought I could see a ring.
There isn't a tension ring.  I don't know much about crystals.  I have a handful and just happened to find one that fit.
Could you possibly take a photo of the dial while the crystal is installed?
One thing you could do is measure the internal height of the crystal if you have a micrometer. I can offer measurements to compare to if that helps, though Sternkreuz probably publish theirs already.
I’m of the opinion that you need a crystal with greater internal clearance. I just compared a 31mm Sternkreuz high dome to a Sternkreuz ATC (with tension ring). The high dome was 4.2mm total height, and the ATC was 4.7mm. That does not necessarily apply to other brands though.
Looking at your photo, I’m not sure that an ATC crystal would be correct or not, as the dial is printed right to the edge. If the case has a large step where the crystal sits (say 1mm or so), then a tension ring would maybe not obscure the dial edge.
I'm not convinced that would be tall enough. Possibly....
What make is the type you have just now? Stella?
Yes, Stella hi dome
I thought of sanding the second hand tip down.  Too drastic?
Edited by Lc130
Yeah, that’s a bit drastic!
I would try a different crystal. Is it worth trying a tension ring crystal? You’d really only want to try it if they are indeed taller at the outer perimeter.
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
