Hi guys
i recently bought a vintage watch and the dial seems to be looking oxidized on the sides... any advice as to how I can restore it? :) tips would be much appreciated!!
A professional watch dial restorer is what you need. You won’t be able to do that yourself.  Oxidization can be caused by damp getting under the glass and it can then penetrate under the transfer of the dial, your watch dial is a transfer. It can also spread to the movement; you might want to check the movement for rust.
A full dial restoration is likely to cost at least £100 (GBP). Plus removing and refitting the dial if you can’t do that yourself - I would be inclined to get it serviced at the same time. See here for example http://www.chealwatch.com/index.php
I would guess that’s an Omega 620 movement in there, and movements / dials do come up on eBay quite often but there are so many variants that it’s hard to find the right thing. You might be lucky and pick up a decent dial for £20 - 30.
Alternatively, if you paid little for it, then enjoy it till it dies and then buy another.
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
