Hi All,
After 6 months of starting out of Seiko 5's I am going to service my Helbros (No idea what model it his if anyone can help?) watch I picked up about a year ago.
From what I have read online you have you access the movement through the Glass as there is no catch/screw on the back. I am looking to replace the acrylic with mineral glass. From the measuring the current glass it measures 30.4mm but has the tendency to fall out if knocked. Will me pushing in 30.5mm mineral glass instead of acrylic cause any issues or really is it just trial and error?
Big step for me as i really have only worked on Seiko's
Helbros.thumb.jpg.ad1dcf17127def4ff56175c0f09dfb1e.jpg1468043995_Helbrosback.thumb.jpg.4550b5b484ee7d51c3dc22dd4abc7fae.jpg
I don't know how a mineral  glass is going to work out for you. In my experience  with that kind of case where the movement  is serviced through  the front  you need a crystal  that is easily removable from the front. Acrylic  fits the bill. Mineral  glass  is not compressible. You might get  it in..but getting  it out would  be a giant  PITA. You should  also have a two piece stem there.the movement  tilts out from the front.
Hi It certainly looks like a snap back case, but thats not to say the movement doesn't come through the front If so as Yankeedog says it would be a PIA if you need to be in the movement through a mineral glass. It looks like its an acrylic and can be removed using the claw.
You were correct comes through the front with a split stem. I have also taken you advise and gone for acrylic in 3 sizes so i can get the right fit.
Also if anyone was interested it is a PEW 1463 movement seems really good condition so hopefully I can pull this one off and service it to full strength. I have taken photos throughout the disassembly as I cant find too much info online in regards to photographs of this movement and will post them in a separate chain.
Hi had a root round the net sure its PEW1463  and not a PUW1463 Had a look on Ranfft web site and found the spec for a PEW1463,  Have a look google    ranfft PEW1463.
PUW1463 - Correct thats a typo by me
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
    • I bought an old Bergeon 5555. The bottom of the tank was full of petrified salts, which also corroded the metal parts a bit. I would use just distilled water.
