This is a basic procedural-type question... When I'm working on engines with lots of nuts and bolts that go in specific places, have various lengths, and other special details (and even when they're all the same just as a matter of good practice), once I've separated two parts I immediately replace each and every screw nut and bolt back where it came from. That way, I have at most a single components' worth of hardware to keep track of (which I usually do by laying them out on my bench spatially as they were removed). If the major assembly is to then go through the parts washer or something, I'll remove the hardware again, lay it out on the bench spatially, clean everything in turn, then reassemble as before. I'm notorious for my swiss cheese memory, and this is a compensation technique that has served me very well for many years.
Cars are a little different though. I noticed in a few of Mark's videos, specifically on chronographs with lots of moving parts beyond the norm, that he does essentially the same thing. Are there any reasons this would not be a good idea as a practice for all types of movements? Could a plate be cleaned with screws in situ like that? What considerations are there that I haven't come up with here?
We all suffer from a bit of Swiss cheese when we get older and mental notes somehow become detached from where they were placed but not to worry we have tablets and mobile phones that save us from messing things up
Not sure about which Mark's videos whow that but cleaning with screws or other parts left on site is not common in watchmaking. For one, is not said that screws always need cleaning. Then, all unnecessary handling takes time and sliglty increase chances of loosing or damaging something. Also, when using shakers or or U/S cleaners screws would likely come lose making everything more complicated. Recently I've got the the mat below that has recessed and numbered pads, which can be useful in keeping sequence and types.
https://www.aliexpress.com/item/33041009496.html
There are a few videos where Mark does this. Namely, chronographs I assume he's not doing every day (probably not the 7750s). He does a few Venuses as I recall, and I think these likely got the screw replacement treatment. I don't recall if he's running them through the cleaner with the screws in like that, but I intend to go back and watch several of his videos over the coming weeks in preparation for getting started in earnest.
I like that mat... A lot... One rolled and lost screw, under any organizational paradigm, and it's paid for itself. Click.
Then I saw this one... It has "mulit" functions... You can see the party in the back! And it flips over to become handy little lids. :-)
Not common and not a good idea are not always the same thing... Not saying it is just yet, just that I'm an out of the box kinda guy and that way of thinking has never stopped me in the past.
Reasons for:
1) Really hard to mess up where the screws go
2) Minimal mental taxation
3) Requires less space and organizational devices
Reasons against:
a) Screws don't always need cleaning
b) Unnecessary handling increases opportunities for mistakes
c) May become loose in the cleaner anyway, and then you're really hosed.
Counters to for:
1) There are other work flows that handle this; eventually you'll figure it out; it's probably good to know where screws go by magic anyway
2) The whole point of the hobby is that it's a challenge
3) Watch movements aren't exactly large...; you'll figure it out and organization becomes a non-issue
Counters to against:
a) Cleaning isn't going to hurt anything
b) It could certainly be argued that it takes less handling in a hobbyist setting since disassembly, cleaning, and reassembly aren't likely to occur in a single sitting; additionally, the work flow is that every screw comes out, is set down, always in the same area, and there's always space due to only one or a few component(s) being removed at a time, and then it goes right back in until it's cleaned and ready for reassembly at which point it happens one more time; that opens up the space requirement and organization benefits
c) Initially, at least, I'll be cleaning with a brush in jars, so this is not an issue since every part will be cleaned individually and with close attention; It's been a long time since I turned a screw on a watch movement, but I don't recall them being especially loosely fitting and susceptible to jostling out of their holes, especially if turned slightly snug
Edited by spectre6000
Just be aware that being made in silicone it will be more sticky and difficult to clean that the traditional type. Probably many "real watchmaker" won't like that. A lot of things like cleaning, oiling, even what tools to use are very subject to personal preferences, different budgets and schools of thinking.
Alright... Good point. Fortunately, I dallied and haven't checked out yet.
If I were to guess, I'd say the traditional option would be leather. That's got me thinking more in terms of work board than work mat... A similar suite of cutouts/indentations could easily be concocted... I wonder if I have any more of that badly dried sapele knocking around in my stash...
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
    • I bought an old Bergeon 5555. The bottom of the tank was full of petrified salts, which also corroded the metal parts a bit. I would use just distilled water.
