Hello Forum,
I started this project of servicing a Seiko 66-9990 (my first "real" project).
I would like to replace the crystal and started looking for information but am struggling to find any specifically for this model (maybe too old ?)
My questions:
- Is there a way to find the correct Seiko reference part number for the crystal for this model ?
- Is there a way to get a "tech sheet" with all Seiko part numbers for this movement (66 A) in case I need to order any replacement parts ?
Many thanks in advance for any help and/or advice
Best
Joao
2 hours ago, FLwatchguy73 said:
this has the part number you're looking for.
Thank you watchguy!
One question though: I came across some ebay listings with that part number for the specific case but how to be sure that the ref is the right one ? You can't allways trust the listings/sellers ... ;)
Thanks again for your help!
Further investigation revealed that the Crystal I initially suggested may not be correct. Boley in Germany has all cases and crystals listed for nearly every model and brand of watch. Please see the screenshot and link below. I would trust the accuracy of Boley's information over anyone on eBay.
https://boley.de/en/case-parts/seiko/20719.6600-9990?q=9990&p=0&s=50&l=18
1761520118_Screenshot_20200423-092703_SamsungInternet.thumb.jpg.b6885c3e76467c948875c1b9293f78b1.jpg
That said, Jules Borel in the states lists the original part number I posted. Jules Borel is also very reputable. Looks as if the original part number is easier to come by though.
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=W]bcWFdcTH
Edited by FLwatchguy73
1 hour ago, FLwatchguy73 said:
Further investigation revealed that the Crystal I initially suggested may not be correct...
I think that both references (318N02AN00 and 318N01AN) refers to the same type of crystal, a 31,8 mm non water-resistant with no accesory (like tension ring etc) acrylic crystal. The 01/02 in the middle of the code is just a serial number for production classification, and the 00 at the end, not specified in the first code, means a transparent crystal.
Cousins have this crystal out of stock, but they say it's expected by 2 June
https://www.cousinsuk.com/search?searchTerm=318N02AN00
Edited by aac58
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
