Hey fellow watch nutters.
Sorry I haven't finished the F05-111 assembly, but here's why....
One of my Mum's friends dropped off an "Heirloom" pocket watch to her, which wasn't running, for me to fix and clean up ... and I can't say no to Mum :)
It's nothing flash, that's for sure.  I'd say it's was probably purchased in the depression and is all they could afford at the time.
I'm not doing a walkthrough on this one ... I know, I know, very slack of me, but I wanted to get this one done and dusted, and get back to walkthrough's that will help others.
BUT, I know you all luv da pics ... so for your enjoyment: here are the reference photos I took along the way  :)
My goodness!  What a mess :o
Time for some case cleaning, and glass polishing!!
No jewels, Pin Lever Movement.  Made in Canada!
Mainspring cover off.
Having a peekeboo between the plates before I undo the case screws and it springs out in ten directions all over my desk ^_^
Bridge off, and here's the movement in all it's glory.
BTW, the Hairspring is attached to the Bridge :unsure:  Lots of fun to put back together
Another reference angle of the movement
Motion Work under the Dial ... Dial was held on my bend tabs
All the parts ready for cleaning.  Note I screwed the Bridge back on, due to the fact the Hairspring is attached to it.
All back together, clicking away nicely, and cleaned up like a new penny .... well sorta :rolleyes:
Hey - a dollar watch - excellent! Westclox were of the same breed as Ingersoll, and of a similar construction. I'm glad to see you were able to get the dial on and off without breaking the tabs. They were never really meant to be mended, just thrown away when broken, so the dials weren't expected to be taken off - hence tabs, rather than dial feet and screws. They really can break very easily after a couple of bends or so either way.
It looks quite decent now you've fettled it - well done indeed.
The movement is almost identical to the Ingersoll that I repaired a few years ago. I found letting down the mainspring a real pain & re-assembly was not easy because of the hairspring set up. As willfly says they were not really expected to be repaired.
Anyway a really good job well done WRT
Beautiful work. I absolutely love seeing something old and cruddy looking restored to its former glory.
Geo, on 29 Jan 2015 - 02:15 AM, said:
Excellent Job, it just proves that you can polish a turd! :)
ROFL!  Perfect description mate.
You crack me up Geo :p
Nice job as always Lawson! This is really a good looking restoration...I imagine all the work considering the original state of the watch!
Great job Lawson
That crystal did come up really well, very similar to the Smiths movements that I work on...
Best wishes
Darren
Lawson,
               For such a recent beginner you have made remarkable progress.  Pocket watch is a job well done.
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
