I am working on an Eterna wristwatch and accidentally unscrewed the bolt that holds the setting lever in place.  I have been struggling for about three weeks now to reinstall the setting lever.  I would REALLY appreciate any and all help.  The problem can be divided into two parts.
1.  How to orient the setting lever into the proper position.
2.  How to hold the setting lever in that position while I turn the movement to the point that I can get to the screw with a screwdriver.
I have tried using Rodico, but that failed miserably and left me with hours of work removing shreds of Rodico.
I have attached two pictures, one without the setting lever and the other with the setting lever in place (perhaps not oriented properly).
The screwdriver points to the place where the setting lever goes.
As stated above all help will be deeply appreciated.
Bill3
Looking at your photos, you still have Rodico all over the keyless works. Use a lump of Rodico to dab all the surfaces until all traces have been removed.
Ideally, you would remove the entire assembly, clean the parts and start again. As a minimum I would suggest you  remove the setting lever spring and fit the setting lever first. Without the tension from the spring it will be a lot easier to position the lever relative to the screw. Use a small piece of Rodico on the setting lever, then put your finger tip on the Rodico to position the lever while you fit the screw from the dial side. then put the spring back.
Guess Rodico is the least of problems you have in this setup.
That spring is in the completely wrong place. if you look at the setting lever jumper you see it has small indentations in it that fitts a small nob on the setting lever, those small indentations are what decide what mode you put the keyless work in, not the setting lever it self.
Edited by HSL
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
    • I bought an old Bergeon 5555. The bottom of the tank was full of petrified salts, which also corroded the metal parts a bit. I would use just distilled water.
    • Can anyone help me identify this watch/pendant. It was inherited by me from my grandmother and I am unsure as to what it is. It's a watch/necklace with a blue face with the inscription "INGERSOLL" and "Swiss Made". Have tried looking online but to no avail. If anyone knows a make/model or knows where I might be able to find out about it, that would be very helpful.
