can I use a dateless wheel on an nh36 movement
By LittleWatchShop · Posted
Update! I've dismantled it, cleaned all the glue off, and rebuilt and lubricated the base movement. I'll leave the chrono part for another day. It's running well - great amplitude and keeping time, but it's got a beat error of 4.8ms. How important is it to correct this? I'm worried that the potential for making things worse having to take the hairspring off and on repeatedly to adjust this. Would anyone here accept it at that?
Since I've been banned from the previous discussion, apparently my language was inappropriate...for small boys. I will start another thread and act in a more decent manner for the girls and ladies of the group. Please what will happen if the forum can't be managed by the administrator, are there provisions in place to preserve the achived member's questions and answers over the years. Please if I may ask these important questions that are important to the members please.
