Hello,
Quite a long time ago I acquired a lot of parts for this movement (though obviously not the ones I'm missing, lol), and around that time also finished up with a partial movement and dial - with some tools and stuff. I originally intended to rebuild the watch and after some time it got forgotten - it would still be nice to complete it eventually.
Crucially it's missing a complete balance wheel and balance cock (I'd make a new case too). I know all the little parts are available, (including the complete balance wheel) however, does anyone know whether the balance cock was available as an official part?
Alternatively, can anyone confirm that a Venus 150 balance cock is a straight swap?
Thank you
What would you ideally want I have a Balance cock and complete case with pushers (apart from crown and stem) ? The balance cock on these is stamped with serial number, replacement parts would not have these.
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
