I have a Longines 340 caliber 14 kt Grand Prize automatic, gifted to me by my late wife in 1961/62.
The watch began to only run for a few hours, then stop.  You could wind it manually, it would run for thre or so hours, then stop.   I took it to a watch repair shop, and was told the watch needed a rotor axel, and they were unable to find the axel.  I found the axel, new in the package, but found the watchmaker at the shop retired.  I took the watch and rotor axel to another shop.  I just got the estimate/ability to repair; they say the mainspring needs to be replaced; it is enclosed in a barrel (which I knew) and they cannot locate one,   By the way, their charge to disassemble, clean, replace parts and reassemble is $475.00 and the charge for the mainspring is $85.00.
What do you suggest I do?  I of course will not be dealing with this watch repair shop, as they are unable to replace the mainspring.
Is it possible to use another longines Caliber sealed mainspring in the 340 movement?  If not, are you aware of where a 340 sealed mainspring can be found and it’s approximate cost?
I’d certainly appreciate any suggestions you may have.
Thanks
I would get a hold of a running scrap movement. I’ve checked eBay, and they seem to sell for around £60. Then find a more reasonable watchmaker with a good reputation.
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
