Looking for a new rotor for my Bulova watch. It’s a 2623,10 caliber witch is the same as a series 262/263 per the watch Bulletin JohnR725 sent me. It’s shows the rotor as a 20.580. Looked around but could not find anyone selling rotors. The question is are they available and who has them.
I think I bent the shaft when trying to install the train wheel bridge. Now I can’t get it back in the lower pivot. Tried to straighten but to know avail. As can be seen in the photo it looks like the magnet is also chipped. The hole that the rotor fits into is about 1.4 mm
Thanks in advance for your help
Dave
You're probably unlikely to be able to pick up an individual part like this.
Like a lot of us, for spares you'll have to keep your eye out on somewhere regularly like ebay for a scrap movement you can cannibalise. Or if you really like the watch your movement goes into then invest in a complete NOS movement e.g. https://www.watchesulike.com/en/bulova/14106-bulova-caliber-2623-10-movement.html
The alternative if you simply like the watch for its case and dial and aren't precious about the movement having association with Bulova is to pick up an inexpensive quartz alternative.
Thanks for the reply. Not really an important watch. Just trying to get to run. I contacted Bulova and am waiting for a reply. Considering a new movement for this one and another one that I have. Just passing time during the “lockdown”
Hope all is well on your end, Dave
I’ll keep all informed. I know I can buy a new movement, but I enjoy repairing  things.
Performed successful mechanical engineering design for 40 years.
    • Good stuff, thanks!!!  I'm going to save it and re-read your post and watch the video again.  I have a few follow-up question:  My understanding is that the spring vibrates or breathes between the the two regulator pins. When the pins are fully open the effective spring length is from the stud and theoretically no rate adjustment can be made by moving the regulator arm. As the pins are closed the spring gets closer to one side of the regulator block but doesn't touch a pin. You can still move the regulator carrier the entire terminal curve without upsetting the coils.  The rate can now be adjusted using the regulator because the effective spring length can be modified.  My question is: Does the hairspring bounce off and touch one of the pins as it breathes? Is that why the effective hairspring length is adjusted by moving the regulator?  And follow-up: How is amplitude affected by the spring between the pins? Does fully open pins, dial up position = max amplitude?  When spring adjusted to 1/2 width still = max amplitude? When I have crown down gravity is pulling the spring against one of the pins and I would expect rate to go up and amplitude to go down. Is that correct?
    • A quick Google for Longines 25.17 found several similar watches - like this one with writing on the case back similar to yours https://benjaminmarcello.nl/product/longines-cal-25-17-tank-from-1938/
    • Apps like Watch Accuracy Meter can be inaccurate, and will read some watches better than others.  What daily rate does Watch Accuracy Meter give you if you check the Longines once it’s been running for 24 hours? Best Regards, Mark
    • Then, can I replace it by purchasing a regular ruby with the same or similar width and height and pivot groove size from eBay? If I replace it like the above and operate the movement, will there be no problem?
