Fusee Clock keeping poor time
4ster
39 minutes ago, 4ster said:
Sure looks like the cone does not match and equalize the properties of the spring
Yes. I would have a look at the spring. Rather than assume the spring is incorrect, I would check to see if the spring is very "set".
I think I'm possibly correct in saying that according to Hooke's law, you may actually get relatively more torque at the start of winding when the spring is set due to the angle of rotation, but I've never measured this myself.
Also, if the spring is too strong it may be too short and nearing or at the end of wind when fully wound. Even with the fusee it may be giving too much power, which with a recoil escapement can actually drop the amplitude due to strong friction during recoil. My gut says slightly weaker spring and slightly lighter pendulum, I do a number of clocks in this pendulum length and 150g is average, springs maybe 0.25 or 0.3 thick, no fusee and they keep time well. Recoil escapement.
There's a lot at play, a well proportioned recoil escapement can give a deadbeat a run for its money on precision. I go with OH's gut feeling that the escapement is dry and possible spring issue. My first step would be get a bunch of Moebius 8300 on those escape teeth and note the difference. Check palettes (again Old Hippy). They should be smooth and polished. If that doesn't help pull it all apart and check the spring. You want generally 3/4 to 1 turn pretension, and have a reserve of 1 wind when the fusee stop piece comes in.
I don't think these clocks where designed to use a light weight pendulum the eight day fusee timepiece movements used a standardised pendulum and bob which is heavy at 250 to 260 grams. Williamsons aim in production was to have completely interchangeable parts between clocks which they achieved at the Salisbury factory before it burnt down.
Another thing you can do why the movement is out of the case is inspect how much torque is getting through the train of wheels at different states of wind - have a feel at how much force there is turning the escape wheel while the pallets are removed. This may give you a better idea about the state of the spring, or if as suggested by others, if escapement friction is upsetting things.
Yeah I was reading about that (the interchangeability), figured the pendulum weight was maybe slightly heavier on a fusee. The clocks I see here with a similar pendulum/escapement are typically "neuchateloise" with either thin springs making 14ish turns of wind with a well engineered outer hook (very even power delivery) or similar with a close to deadbeat escapement and good hook- bridles, not holes, and a more typical 6 turns of wind.
My gut feeling is too strong mainspring (short) and possibly dry and/or damaged pallets.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
