Hello
Yesterday I cleaned and oiled a certina waterking. There was a lot of gunk in the movement that prevented it from running, but after cleaning and oiling the movement it was running perfectly, but for some reason the hour hand and minute hand doesn't move sometimes. My hypothesis is that I put too much oil between the centerwheel pivot and the Canon pinion... Could that be true?
More likely the canon pinion needs tightening. Is the seconds hand moving normally, and how loose does the crown feel when setting the hands? It shouldn't feel too loose.
Yes, setting the watch is very loose. It has sub seconds and the second hand tics as it should. How do you tighten the Canon pinion? Just press it harder on the centerwheel?
4 minutes ago, Nucejoe said:
Tightening canon pinion is reducing ID of its tube. I use a dulled nailclipper.
Ah, okay. Thanks!
Make sure you put a piece of brass wire in the canon pinion, roughly the same size as the inside diameter of the pipe, just a tad smaller, to make sure you don't crush it too small when adjusting it with nail clippers or a canon pinion tool on you staking set
If you do press it too tight, you'll know, because setting the hands will be really stiff, then you'll need to broach the pipe of the canon pinion out a little to increase the size that you tightened too much
Nope!!
If you look at your canon pinion closely you will likely see (but not always) a divot in the tube part as indicated above. This is where the tube has been crimped to make it a tighter fit on the center wheel pinion, which is what you need to achieve.
As @Jon points out though you need to ensure that you don't crush the tube so much that it no longer goes onto the center wheel pinion at all, which is where inserting a wire all the way into the canon pinion tube helps as it limits the amount that it can be crushed. The wire needs to be just a tiny fraction smaller than the tube. If it's too small then you will still squash things too far and will need to open the hole out again with a broach. Too big and you won't be able to crush it enough to make any difference. The best approach is to adjust the fit in small steps, test fitting the canon pinion each time until you are happy with the fit.
You will also need to avoid crushing the tube so tightly onto the wire that you can't the extract the wire.
Good luck :-)
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
    • I bought an old Bergeon 5555. The bottom of the tank was full of petrified salts, which also corroded the metal parts a bit. I would use just distilled water.
