I damaged a lug slightly and would like to repair. I saw there are pads and brushes however I’d like to hear from you. I never did anything like that.
Hi  depends on the the dammage   deeper sctatches  7447 and work backwards for the required finish  licht dammage  7754 will probably do, patience is the key a little at a time.
Unfortunately that looks like a really deep ding. It l might look odd if you completely rub back to eliminate. If it was me i would rub gently with a 2000 grit emery only rubbing in the same direction of the grain already present until it looks reasonable then STOP. You can take off but you can't add.
PS I have the same watch and I love it .
It looks like a Fibreglass scratch brush to me,  if so it might be a bit harsh as hey are used to remove heavy staining.  If you are not sure I would leave it alone. As you say if it starts to look different you will have to do the whole watch case & then will it look right for a Rolex.
As clockboy says, it’s a deep ding. I’d just leave it as you can’t simply brush over it as it has raised the material surrounding the indent.
The brushing is coarser than you might expect. Probably somewhere in the 400 grit region.
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
    • I bought an old Bergeon 5555. The bottom of the tank was full of petrified salts, which also corroded the metal parts a bit. I would use just distilled water.
    • Can anyone help me identify this watch/pendant. It was inherited by me from my grandmother and I am unsure as to what it is. It's a watch/necklace with a blue face with the inscription "INGERSOLL" and "Swiss Made". Have tried looking online but to no avail. If anyone knows a make/model or knows where I might be able to find out about it, that would be very helpful.
