Hello fellow watchmakers,
in the photos attached you will see a white and black dial which was re lumed using pre mixed patina lume in a syringe nothing was added. It has the perfect matte powdery looking finish like vintage radium lume but color is too orange almost like a yellow ochre, i added instant coffee to the mix before application on the dial in the case, has a better color like a burnt sienna but it has a gloss to it. Iam not a fan of using varnish so I need to figure out a way to get the finish of the orange lume with a color more like burnt umber....as an artist umbers have a bit of green and them, so adding anything to the original mix gives a yellowish brown color. Radium lume looks more like burnt umber.....I was thinking of using match green tea powder with the original mix hoping it won’t add a sheen to it. When I search online all I hear about is coffee (which is usually added after application) and baking. I can’t bake a porcelain dial and coffee isn’t giving me what I need. I did hear someone using cigar ash or graphite anyone have any suggestions.....burnt umber color with a matte finish.
First thought is watercolour blocks which come in a huge array of colours and would give you the matt effect as well as fine control over colour. They can easily be ground to a fine powder and added in small quantities to a mix.
Also consider that a constituent of umber is iron oxde ... or rust. Making your own rust powder is easy enough and I would think provide a better matt finish than coffee powder.
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
    • I bought an old Bergeon 5555. The bottom of the tank was full of petrified salts, which also corroded the metal parts a bit. I would use just distilled water.
    • Can anyone help me identify this watch/pendant. It was inherited by me from my grandmother and I am unsure as to what it is. It's a watch/necklace with a blue face with the inscription "INGERSOLL" and "Swiss Made". Have tried looking online but to no avail. If anyone knows a make/model or knows where I might be able to find out about it, that would be very helpful.
