Hi
The balance wheel stops because when it's running, it's not horizontal from side view and touches the pallet fork bridge by tilting. It's a EB 8021 movement. There seem to be enough end-shake. I replaced the staff by the way, but it should be aligned when pitted back together. The wheel is flat when trying to twist it, so the balance jewels are not damaged.
your paragraph is confusing? If it's not parallel and touches the plates there is a definite problem. But if it's also flat when you twist it that indicates that it's parallel which conflicts with the first statement you had that it's not parallel?
So when restaffing a watch before you put the hairspring on it before you put the roller on you put the balance wheel with its new staff in to make sure it spins nice and that it is running parallel and not wobbling was that something that you did? Then once you verify that it looks right then you can put the rest of the stuff on like the roller table next to verify that it engages with the fork then finally the hairspring.
also watches like this specifically pin lever watches are made the price. So even though they have screws and can be disassembled there really really cheap and they're going to have issues.
also in your photograph I can see the lower pivot of the balance staff but I can't see the upper because they hairspring is blocking it. So perhaps put the balance wheel back in the watch the bridge back down and a sideways pictures so we can see what that looks like.
https://17jewels.info/movements/e/eb/eb-8021-68/
Agree with John, I suggest you go back to the basics, remove the mainspring and roller table & check it spins freely without any wobbles.
Hi
Thanks for informative replies. I see I need to acquire a truing caliper to check the wobbling. This was my first attempt to  re-staffing, so appreciate the feedback. Here are some pictures as required. Yes, these movements are cheap and containing brass here and there and can be damaged and scratched easily.
Edited by Khan
the good news is I can see the pivots and they look straight and they're still there.
Something that I can't see is what does the balance staff originally look like? then did you physically compare the original staff with the replacement staff?
then there's something is bothering me but looking at the close-up I'm not quite sure? Normally the roller assembly would be tight against the hub and you have a gap? But having not seen the original staff it may be tight against something it may be exactly where it's supposed to be.
So the next picture would be put the balance wheel in the watch without they hairspring and see if the balance wheel turns and of it that some weird angle get a picture for us
Hi John
Thanks again for taking time - great feedback. The replacement was an original - Yes, it has an extra shoulder making a gap between hub and roller. Attached picture is another attempt of staffing, as I somehow broke a pivot on previous one, it seemed weak though...I had various staffs and chose one closest to the size. The pivots were thicker, so I "filed" them thinner with a fine stone. The wheel is more balanced and not touching anything anymore, but the wheel doesn't turn, I think the pivots are tightening against the jewels. Anyways, a complete balance replacement might be easiest. I considered this as a fun project to practice on. But cheap movements are fragile and clumsy to repair!
Edited by Khan
when you modified them with the fine stone did you do this by hand? Or did you have access to a watchmakers lave?
then staffing a watch is usually not a beginner's task. That's because you need to understand a whole bunch of stuff  basically have a really good understanding of how the balance wheel works in the watch so if it's not quite right it makes it a lot easier to grasp what's going on. Then depending upon the watch the replacement staff will have issues. For instance American pocket watches lots of variations for the same staff number. Or pivots they came in a whole variety of sizes. Or replacement staffs that are made larger on the grounds of the watchmaker will shrink things to fit. This would include things like the length of the pivots being too long. So you have to bill understand how to shorten the pivots properly.
so unfortunately it means changing a balance staff is not a plug-and-play operation and is going to work perfect in every single incidents there will be times that does happen and other times you're going to have to fit the staff. This is where a watchmaker's lathe comes in very handy.
Thanks again for sharing great knowledge!
I filed the pivots by hand. Quite paranoid situation, as I was always afraid to file too much.
I did another experiment on another watch cal. Urofa 58 but the ordered staff had exactly same size hub as the whole in the balance wheel. The old staff had bigger hub. In such case, I guess the staff is useless?
By the way, I did both the dismantling and assembling of the staff by a staking set and not a platax tool. Is it no go? I noticed the wheel can bend if punching too hard.
the normal procedure when changing a balance staff is to attempt to figure out and secure a replacement staff. We will note I'm giving you the ultra short version because some watches will have a lot of very options for staff even with the same part number. This is typical on American pocket watches. Then once you have the replacement staff it's important to measure not just visually look at it but measure the old versus the new. This will avoid any unpleasant surprises.
If the new staff needs to be modified like the pivots are too big it's always best to do that before you put it in the balance. Often times replacement staffs will be bigger than they need to be so the watchmaker can reduce things to fit. usually the pivots are too big and need to be reduced in diameter sometimes shortened. Occasionally the entire staff is physically too big but that is usually an aftermarket staff.
staking set works fine it's the classic tool to take out and put in a balance staff but you do have to understand what you're doing and how to do it otherwise problems will occur.
at the link below you want to scroll down to the section titled "Joseph School of Watch Making" it would actually be better to have a physical book or the complete PDF but in the absence of that the website version can be used some stuff isn't quite complete though.
so for instance section 4  explaining how to refinished pivots with a variety of techniques. But if you're putting in a balance staff the same methods will work for reducing the diameter the staff and shortening the staff.
so whole bunch of chapters on balance staff replacement you might find it helpful to read some of this
https://www.mybulova.com/vintage-bulova-catalogs
6 hours ago, Klassiker said:
Is it me, or is the entire balance cock in that last photo crooked?
Looks that way to me too, and looks like a couple of screws coming in from the dial side a bit too far and possibly interfering with the cock?
Thanks to all for replies. The balance wheel sits quite high on this movement, so the screws from dial side doesn't touch. The balance cock looks crooked because I might not have pressed it down correctly.
5 hours ago, Nucejoe said:
You may have inserted a wrong staff in.
Begining to wonder if pivot is inside the jewel hole.
maybe be best to go back to the beginning like where did the staff come from? Did you compare the new staff to the old staff preferably with a measuring device not just your eyes?
then what was the perceived problem that required filing the pivots by hand?
I looked up the staff cross references back to the base model of 1553. I have a complete list of all the watches that use this staff. Also website below they sell balance staffs but more important they give dimensions. Also the bestfit book has dimensions I snipped out that image the numbers all agree so that should be the size of your staff.
100/1659
Factory Number:STAFF/BET 1553
BET 1553
BET 1554
BET 1579
BET 1605
BET 8020
BET 8020N
BET 8021
BET 8021-68
BET 8022
BET 8022N
BET 8023
BET 8024
BET 8025
BET 8027
BET 802IN
https://www.balancestaffs.com/eb.php
I filed the staff by hand because the pivots were too thick for the jewel holes. I only measured by eye. The staff came from an unsorted group of staffs I have in stock. The hub diameter and height matches pretty much. But the pivots dimensions were different. I think there is much more theory into it that I should discover. I appreciate all the help provided in this forum. Thanks again!
    • Hi Can this pusher screw be straight again and how?
    • Typically watch manufacturing companies will purchase parts to their exact specifications including the jewels. This means that typically you may not find an exact generic replacement. I'm attaching a PDF of a book that explains how to replace jewels. Seitz book.pdf
    • Hey everyone! I sure this topic has probably been discussed before, but I want some good recommendations based on experience or knowledge about a good affordable high torque DC motor that I can use for my lathe. I have a little lathe but it has the regular old style motor that was used in the past with a foot controller. However, I would like to improve it by buy a nice motor with a speed controller so I don’t have to use my foot. I would like the motor to have really good torque so that even if I run it at a very low speed, it still can cut material easily. I saw online this brand called Servo sewing machine motor with a speed controller, but I don’t know how good they are and if they would work like I would like to for my lathe. Thank you for all the help!
    • Your only partially correct here. Let's look at a magnified view of the image up above. Then for a flat hairspring to function correctly there has to be a little bit of breathing room unfortunately. If you would like Better timekeeping if you get a watch with the over coil hairspring then those regulator pins are supposed to be as tight as possible but still allow the hairspring the slide. With if the pins are opened up at all you'll see a dramatic timing change based on amplitude. So in our example down below initially hairspring is basically free-floating not touching anything the effective length of the hairspring is at the stud. As the amplitude picks up at some point in time they hairspring will just tide should one pin on one swing and the other pin on the other swing. As soon as it does that it changes the effective length to being closer to the regulator pins. As the amplitude picks up more and more it's obviously touching the regulator pins more and more and the length of the hairspring shortens the watch speeds up. This is where in your video at around 16 minutes he opens up the regulator pins and the watch slows down. This is because they hairspring is no longer bouncing off either pin as much. Then because the watches running slow he speeds it up just to show that yes you could regulate the watch but now you have a problem. Because the regulator pins are much farther apart amplitude is going to have a much greater effect. Like in the image down below they hairspring is properly spaced between the pins. But if those pins are farther apart the effect of amplitude will be much greater. So he speeds up the watch to cancel out the effect of the regulator pins at the particular amplitude which was dial down then when he moves the watch to a crown position which will always have an amplitude decrease because the amount of friction on the sides of the pins now the hairspring is not touching the regulator pins as much and the watch dramatically slows down.   Let's look at the other example image. In this particular example they hairspring is actually touching the regulator pin at restWhich means the effective length of the hairspring is at the regulator pin the watch runs fast. As the amplitude picks up hairspring will lift off the PN moving the effective length towards the stud which is why the watches slowing down. As you can see is the amplitude picks up They hairspring is not centered C not getting even timekeeping and the watch is slowing even more down. But at some point in time when the amplitude gets high enough this will depend upon the watch the spacing Excedrin whatever the amplitude is will be balancing actually between the pins in the watch will of course speed up and then at some point time you reach that sweet spot where it's bouncing between the two pins but as you can see it's at a much higher amplitude. So this is why hairspring has to be properly centered between the pins and the pins have to be at the right spacing otherwise you going to get strange timekeeping based on amplitude which no matter what you're going to get a little bit of that as you do have to have a little bit a spacing. At least on a flat hairspring.
    • My understanding is that In the Etachron system the spring is only centered n order to set the stud angle when the the pins are wide open and the regulator block in at the midway point.  After that the pins are rotated in one direction only so that the width between the spring and one of the studs is 1/2 width of the spring. This results in the spring always being closer to one stud than other one.
