Hey
Any one familiar with this watch?
This is the bottom of the 2 center wheels. Is this supposed to connect to the alarm mainspring barrel?
Yes i took pics as i stripped but missed this bit.
cheers
gary
I'm pretty sure that those two aren't supposed to mesh.
The alarm mainspring barrel should mesh with the alarm star wheel pinion.
Hi
Yer that.s the problem my watch is a 2612.1. i have the tech sheet for the 2612 but are they the same?
Cousins say they do not  have a part i require for the 2612.1 but they do have it for the 2612.
Also ranfft say they are both based on a AS 1475 but then the part numbers are different.
What i really want to know is my watch the 2612.1 the same as the 2612 0r the AS 1475.
Or are all different.
I am just hoping someone has had a similar problem before and may be able to point me in the right direction.
cheers
gary
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Poljot_2612_0
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Poljot_2612_1
They look virtually identical, (all be it that the balances in the three examples on Ranfft are different, but this is probably simply down to manufacturing variations over time).
The stem, dimensions, mainspring, bridges etc look the same.
Edited by AndyHull
If the one that you've installed in the alarm train doesn't mesh with the star wheel pinion is it possible that you've go the barrels muddled up?
Ok, are the pivots on the star wheel pinion intact and properly seated in their jewels?
hey
All seems fine as far as i can see. canon pinion may be a bit loose. if i could i would change it for a new one.
But as i say i don.t know what part to order.
need escape wheel and canon pinion.
So i shall scour the net but not holding out to much hope.
not a lot on ebay .
Cousins has all the parts for a 2612 but none for 2612.1 so a bit stuck dont want to buy the ones for the 2612 only to find they dont fit the 2612.1
thanks for all the suggestions though.
cheers
gary
  • 4 years later...
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
