Hi
I am trying to fit a new piwot in my brothers pocketwatch. I will try this before fitting a new balance staff.
During my preperations i am reading Donald de Carlos repairing book, and my understanding english i not so good.
It stands: Let the temper of the arbor down to light blue.
Does it means increase the temper to light blue with a flame,and then let it cool down?
Mvh Tore
It means reduce the temper to a light blue so as to make it able to be drilled. Normally they are hard and would not drill easily,                 Resulting in breaking or blunting the drill.             Making the staff workable     cheers
 Sorry for not understanding.Does that means heat the arbor up and the reduce temper of arbor to light blue.
Tore
I guess one can say temper in this case just means to heat it up, since the pivot material probably earlier got heated up to quite high but a specific temperature and then quenched in water or oil just to make it harder. One could say the time it takes for a material to cool off determines its hardness.
In this case you just warm it up so it gets a light blue color and then let it cool off in air. This process makes the material softer and easier to drill.
Steel (alloys that are hardenable) is hardened by heating to its critical temperature then quenching, depending on the alloy the quench may simply be ambient air, water, or oil (there are other quenches but those are the main ones).  The critical temperature for common hardenable steels is around 800 degrees C. A typical alloy used in watchmaking would be quenched in oil. When quenched, it will be fully hardened.
In almost all cases fully hardened steel is undesirable. To reduce the hardness it will be heated to a temperature below its critical temperature, and this is tempering. Most watch components would be tempered to a "blue" state; the tempering ideally might take several minutes or more, but the cooling off time once at color (or temp, being more scientific) is not of any great importance.
Blue steel is able to be filed, but not able to be sawed with normal metal cutting saw blades (this is the test some schools used to use on student work to see if they were heat treating correctly); it is also difficult to drill unless special drills are used.
To reduce the temper on a piece of steel it would be heated past whatever color it was originally tempered to. The color range goes: straw, brown, violet, blue, light blue, then more or less the natural steel color. When tempered to its natural color it is still harder than in the annealed state, but not generally hard enough for use.
To temper a watch arbor or staff, a typical technique would be to drill a piece of brass rod with an outside diameter of perhaps 3x the piece to be drilled, the drilled hole will just let the workpiece fit freely. The brass rod is heated with an alcohol flame and when the visible steel protruding from the hole is the desired color remove the rod. The steel will not cut as freely as annealed steel but much more easily than blue steel.
Edited by nickelsilver
There's a lot of mixing up of terms in steel heat treatment, even professionals who have studied it mix up hardening with tempering sometimes (it's a pet peeve of mine).
In my education to reduce the temper is to take the tempering to a lower state of hardness, but now thinking of it from a "blank slate" perspective it's illogical; something that is less tempered than more tempered is in effect harder!
At any rate, tempering can only make steel less hard, never more hard. Only heating to critical temp and quenching can increase hardness.
    • Your only partially correct here. Let's look at a magnified view of the image up above. Then for a flat hairspring to function correctly there has to be a little bit of breathing room unfortunately. If you would like Better timekeeping if you get a watch with the over coil hairspring then those regulator pins are supposed to be as tight as possible but still allow the hairspring the slide. With if the pins are opened up at all you'll see a dramatic timing change based on amplitude. So in our example down below initially hairspring is basically free-floating not touching anything the effective length of the hairspring is at the stud. As the amplitude picks up at some point in time they hairspring will just tide should one pin on one swing and the other pin on the other swing. As soon as it does that it changes the effective length to being closer to the regulator pins. As the amplitude picks up more and more it's obviously touching the regulator pins more and more and the length of the hairspring shortens the watch speeds up. This is where in your video at around 16 minutes he opens up the regulator pins and the watch slows down. This is because they hairspring is no longer bouncing off either pin as much. Then because the watches running slow he speeds it up just to show that yes you could regulate the watch but now you have a problem. Because the regulator pins are much farther apart amplitude is going to have a much greater effect. Like in the image down below they hairspring is properly spaced between the pins. But if those pins are farther apart the effect of amplitude will be much greater. So he speeds up the watch to cancel out the effect of the regulator pins at the particular amplitude which was dial down then when he moves the watch to a crown position which will always have an amplitude decrease because the amount of friction on the sides of the pins now the hairspring is not touching the regulator pins as much and the watch dramatically slows down.   Let's look at the other example image. In this particular example they hairspring is actually touching the regulator pin at restWhich means the effective length of the hairspring is at the regulator pin the watch runs fast. As the amplitude picks up hairspring will lift off the PN moving the effective length towards the stud which is why the watches slowing down. As you can see is the amplitude picks up They hairspring is not centered C not getting even timekeeping and the watch is slowing even more down. But at some point in time when the amplitude gets high enough this will depend upon the watch the spacing Excedrin whatever the amplitude is will be balancing actually between the pins in the watch will of course speed up and then at some point time you reach that sweet spot where it's bouncing between the two pins but as you can see it's at a much higher amplitude. So this is why hairspring has to be properly centered between the pins and the pins have to be at the right spacing otherwise you going to get strange timekeeping based on amplitude which no matter what you're going to get a little bit of that as you do have to have a little bit a spacing. At least on a flat hairspring.
    • My understanding is that In the Etachron system the spring is only centered n order to set the stud angle when the the pins are wide open and the regulator block in at the midway point.  After that the pins are rotated in one direction only so that the width between the spring and one of the studs is 1/2 width of the spring. This results in the spring always being closer to one stud than other one.
    • The idea is that the spring is centred between the pins when at rest. Then when the watch is running it will oscillate equally between the pins i.e. bounce off one pin then the other, as the hairspring breathes. If the spring is only hitting one pin, then it isn't centred, and most likely the pins are too far apart. Yes, the regulator pins are there to adjust the effective length of the hairspring. The spacing of the regulator pins should not affect the amplitude.  The vertical positions typically have lower amplitude than the horizontal ones. This has nothing to with the regulator - hairspring interaction. Increased friction in the verticals sucks energy from the system and reduces the amplitude. If the amplitude is less, the breathing is less. More tim between the pins = more effective length. Depending on how well the hairspring is centred, and which direction it sags, some vertical positions might run faster than the horizontal ones, and others slower. For example, if the spring is off centre towards on pin, and pressed against it by gravity, it might never bounce off that pin => faster. At the position 180 deg. away, the spring will spend more time in between the pins => slower.
    • Thank you all for the tips and insights. I'm looking carefully at the Sherline lathes with a milling attachment. I need to figure out exactly what I'd need to get in terms of the base lathe and attachments to be able to fabricate basic parts and learn how to fabricate some of the less basic ones- like a cannon pinion. Thank you again.
    • Welkom Sebastiaan! Veel plezier met deze hobby!
