my preferred watches are the the chronographs due to the extra complexity of the repairs and the calibration.  I had a sort out and realised that i have tons of stuff!
Need to start using some of this stuff once i sorted out whats from a Valjoux, Landeron or a Venus!
Thought id show some pictures, because my other half was not impressed at all!
Edited by jnash
Should be at least one good one amongst that lot.   :thumbsu:
Theres plenty, most are working!  now i need to find some projects with cases to work on!
Nowt wrong with having spares - yours look impressive though and will induce envy from all us like minded addicts
Cheers,
Vic
  • 5 months later...
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
