Hi
I am not having any luck trying to find out about this.
Cousins turns up a blank when I input the calibre etc, as does Borel. I was hoping to find if a new crystal and gasket were available.  Also just checking, is the crystal held in by a screw down ring and are they usually very tight. I’ve not tried to loosen it yet but if that’s how they are held I will need to improvise some sort of tool.   The numbers on the caseback are 5518-S96567.
Many thanks for any suggestions.
Well thanks, that’s most helpful. I must be doing something wrong, I tried several times. Did you put the # sign in as they say or just  4-S96567?  I’ll try it myself later and see if I can do it.
Thanks again:thumbsu:
If you click the little info box next to Citizen it explains it some. From what I've found, citizen case references are always 4- something. The reference itself will be the part after the dash on the back of the case.
Hope that helps, I'm just going off what I've found, I don't know 100% haha.
