I’ve always been really impressed by the lapping machines that are used to achieve flat faces and crisp on cases. Although I don’t do enough case refinishing to warrant the price of a machine, I though maybe I could achieve a similar result with something home built. The impetus to try came when I bought an Omega Chronostop. The case came with a sunburst case finish that was long gone and would require precise brushing.
I figured I could replicate the multi-axis adjustment by using a telescope head. Found one on eBay for $125. Then added a 3 jaw Chuck for $50. My only issue was that I needed to adapt the two together. Because the stress won’t be so high I figured I could just 3D print some adapters and it worked perfectly! The great thing about the resin printer is that the resolution allowed me to actually print the threading!
Because the case is a top loader, there was no good way to hold it properly so I printed an adapter to screw on the back.
All ready to go:
I am really happy with the results! The case has some dings that I wish I could laser weld but alas I can’t built one of those on the cheap. Lol.
My next step is to find a way to fasten everything down so I get more consistent engagement with the sander and recreate the angles consistently between checking my work.
- Craig
  • Like 8
  • Thanks 2
b16d832fea794475f7f6cf471a810137.jpg&key=0abb212ddcde109e58b045ac9de19ed323f585c0187e7406af5b1d3d5db7c120
fe21126fad465174b6360150762ebb5e.jpg&key=8f4a5b3a4c7e403b2727c1447afb18f33904d4d378dfac117d947b73a4aa6698
9869b7c960c464091c188749e99f6cf9.jpg&key=7902528277c923334fceff7f49cdfee944f3073dba74dfb975f02d4fed78152e
479436545e9dc105891b3f9d547fb9e5.jpg&key=ae0ef434276a306b099ba20c4723643a40cac1d94eeb957352ea466f46333143
All ready to go:
fea3e97456b07bdee6da31e0ab1301f3.jpg&key=16fdd4d1159fcf7621e89700da43fdf840361d37fa623206fc6b59238498f364
7e40ee64a1e3182417c598126d013c95.jpg&key=4ab541031e578979722c82977171d3e6eaae3b677b6a6295085c1c9364237d3e
ebd90dc1f0f7cb13cde9628e2b7a4a27.jpg&key=c6ccf1f93745c83fe6fbf1dd09bfcc32c34b728c7abbcabf2ec59a4b83d15a8f
- Craig
Nice Idea, can you please post the ebay link to the telescope head.
My exact listing is gone but the parts are:
- Celestron Astromaster CG-3
- CME 2”/50mm 3 jaw Chuck
Nitpick, the market price for that type of chuck is a little more than $30 shipped. Alos interesting the below for $22, from the jaws casting marks it appears they are of a softer alloy, which is good to preserve the finishing of the work.
https://www.aliexpress.com/item/4000276565113.html
  • 10 months later...
  • 2 years later...
