I am ordering some things, and thought I'd try again to get this guy back on the road. The Incabloc springs fell out, and I broke one trying to get it back in. I tried micing it, but what I'm getting doesn't line up with any of the springs I see on the Incabloc parts chart. I was hoping to back door it by seeing if I can figure out what setting the movement it's based on is supposed to have, but I can't figure out what the movement is. The only markings are a faint "+ -" on the balance cock, and a star on the rotor (pictured, but difficult to see) that was under a decorative plate.
It's a Chinese "13767", which is a version of the "Chinese Standard Movement". I found it elsewhere down to the faint star on the rotor. Still no idea what size the Incabloc springs are though.
Edited by spectre6000
Considering that the Chinese never bought from Incabloc, do not necessarily make precise 1:1 copies, and have build the Tongji in very many different variations and independent factories, I think the only way to to know what you copy has, is with measure and compare.
I measured it out, but the measurements didn't line up with anything out of the Incabloc catalog. I took a step back, and assumed I was simply having a hard time getting a good measurement on such a small and flexible piece, and thought maybe I could approach it from the angle of seeing what would have come with whatever movement it was based on. Once I realized it was a Chinese original, I pretty much figured I was screwed. I placed my orders for everything else, and I guess it's just going back to the "art" bucket. My order from Switzerland finally made it to Queens, so hopefully I'll be moving on to movements worth buying parts for soon.
    • My understanding is that In the Etachron system the spring is only centered n order to set the stud angle when the the pins are wide open and the regulator block in at the midway point.  After that the pins are rotated in one direction only so that the width between the spring and one of the studs is 1/2 width of the spring. This results in the spring always being closer to one stud than other one.
    • The idea is that the spring is centred between the pins when at rest. Then when the watch is running it will oscillate equally between the pins i.e. bounce off one pin then the other, as the hairspring breathes. If the spring is only hitting one pin, then it isn't centred, and most likely the pins are too far apart. Yes, the regulator pins are there to adjust the effective length of the hairspring. The spacing of the regulator pins should not affect the amplitude.  The vertical positions typically have lower amplitude than the horizontal ones. This has nothing to with the regulator - hairspring interaction. Increased friction in the verticals sucks energy from the system and reduces the amplitude. If the amplitude is less, the breathing is less. More tim between the pins = more effective length. Depending on how well the hairspring is centred, and which direction it sags, some vertical positions might run faster than the horizontal ones, and others slower. For example, if the spring is off centre towards on pin, and pressed against it by gravity, it might never bounce off that pin => faster. At the position 180 deg. away, the spring will spend more time in between the pins => slower.
    • Thank you all for the tips and insights. I'm looking carefully at the Sherline lathes with a milling attachment. I need to figure out exactly what I'd need to get in terms of the base lathe and attachments to be able to fabricate basic parts and learn how to fabricate some of the less basic ones- like a cannon pinion. Thank you again.
    • Welkom Sebastiaan! Veel plezier met deze hobby!
    • Welcome to the friendly forum.  Enjoy
