  • 3 months later...
I think lepsi has most of the lift angle i need .But can't find any for Tissot 782-1 movement .
Does anyone now which lift angle .
The lift is 52 for that cal and also the 782-2. :)
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
