I've just put a '67 Timex Viscount auto back together and I'm having a strange problem where the hour hand doesn't keep up to the minute hand (noticing this while setting the watch) and then it bolts ahead an hour or more very quickly. I've had to adjust the lay of the minute and second hands because they were rubbing every once in a while and stopping time. Perhaps I pushed the hour hand down and it's rubbing on the face now? I have to open it up again anyway as my micro-adjustments of the minute hand aren't keeping it away from the second hand consistently. It could just be that I need to make sure everything is getting clearance a little more closely or could it be something with the way the hour wheel and cannon pinion assembly are meshing?
Quite possible  was there a dial washer on the hour wheel and has it gone back on.  The hour wheel could be slipping over the min wheel.     Check the canon pinnion as well
