Hello, I am working on an AS 1320 (Bulova 10BRC, 9AS) automatic movement and have found it to be missing a part for which I cannot find a name. I have looked at the 10 BRC automatic assembly parts list and the parts list for the movement itself and still cannot locate it. Here is a photo with the missing part outlined in red.
It is a spring-like device that prevents the automatic assembly's third winding wheel from engaging the ratchet wheel when the mainspring is fully wound. If anyone could tell me the name of this part so I could order a few replacement parts, I'd really appreciate it!
25 minutes ago, oldhippy said:
Can you post the link to the parts list or up load the list please.
I rember the part name list.    haveing a hard time finding it !    i'll keep looking.     vin
Hello, I used the Bulova Self-Winding Watches booklet (pg 18) and the '52 Catalog of Interchangeable Parts (pg. 79) to attempt to identify as many parts as I could.
15 minutes ago, Walsey said:
I don't believe that is the part but thank you.
  • 4 years later...
Plot twist, the Bulova 10BRC doesn't use the Breguet spring! Although it's based on the AS 1320 the Third Winding Wheel is constructed differently and the spring isn't used. The 1950 'Bulova Self-Winding Watches' manual shows how the automatic works functions and lists all of the parts. They also latter released an addendum to clarify the recommended oiling in the 1952 Technical Bulletin No. 2 (attached).
Bulova 1952 Self-Winding Technical Bulletin No 2.pdf
Strange how it's on the parts list then?
I saw that and thought the same. I believe it's an error. I have two of the 10BRC and neither have that spring. I've looked at a number of the 10BRC movements on the web and can't see the spring. The Bulova parts list and description of how the automatic works functions does not mention the spring either in the parts list or when describing how the automatic works functions. The lubrication recommendation does not mention lubricating that spring, while the AS 1320 technical documentation does.  I believe that the different construction of the Third Winding Wheel in the 10BRC compared to the AS 1320 is why Bulova did not include the spring.
So is that just an empty space on the 10BRC?
Yes, it has a cutout for the Breguet spring (photo), the screw hole and the steady pins but no spring. The pinion on the bottom of the Third Winding Wheel on the Bulova is solid with the wheel and engages with the Ratchet Wheel. On the AS1320 it has a clutch wheel that can slip and disengage from turning the wheel when the watch is manually wound and it needs the spring to keep it engaged with the wheel. I'm not sure why this is necessary as the the auto works will also disengage from winding the rotor when the movement is wound because when it is wound the alternating disc rotates away from the rotor.
That Technical Bulletin I posted above doesn't come out and say it but it sounds like this setup with the Bulova might be a design issue:
Quote
Whenever the click becomes inoperative, another serious possibility is a broken third winding wheel. This can result as the stored up power of the mainspring is released against the pivots of the third winding wheel before the main click snaps back into the ratchet wheel.
Another cause of breakage of the third winding wheel can be due to excessive resistance of the safety in the mainspring barrel.
Perhaps not having that slipping clutch (a cost saving measure?) leads to problems with the Third Winding Wheel breaking.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
