manodeoro Posted May 31, 2020 Posted May 31, 2020 After working on it for a few months I've think it's time to create a specific thread about the Ingersoll Sealion that @Johnnie offered me on that thread here. I already had made a custom bezel for it, as neither Johnnie nor me ever found anyone available on the web, but I had made it a little too "aged" and to "orange" so it didn't really matched the color and condition of the dial. So yesterday I've decided to redo that bezel and, while there, do some more renovation work. So I've dismantled it once again, polished the case, crown and caseback a little more, used some toothpaste and polywatch to get a nice clear and shiny plexi. After polishing the caseback I took a close picture and saw that it certainly had, at a time, some brushing on the flat part which is engraved ... so I've decided to try to redo that brushing and here is the result ... CASEBACK AFTER POLISHING CASEBACK REBRUSHED After casing the movement and before putting the caseback on, I've took some pictures of the Ronda 1217-21 movement ... RONDA 1217-21 INGERSOLL ENGRAVING 1217-21 MODEL ENGRAVING SWIIS ENGRAVING ... so that movement is definitely Swiss And the nice Ronda star with RL inside ... probably meaning "Ronda Lausen" And now today's wristchecks ... showing the "finished" watch with it's new bezel, less aged and more reddish ... Maybe some day I'll dismantle it again to redo the lume, which is almost "dead" ... of course if I do that I'll take care to make the lume really low, as it should be on a 43 years old watch ... 2 1 Quote
manodeoro Posted May 31, 2020 Author Posted May 31, 2020 Thank you[mention=2964]Johnnie[/mention] I just got a new avatar [emoji39] 1 Quote
AndyHull Posted May 31, 2020 Posted May 31, 2020 Very nice. A quick "How to" on making that bezel would be greatly appreciated, it really hits the mark. 1 Quote
manodeoro Posted June 1, 2020 Author Posted June 1, 2020 Very nice. A quick "How to" on making that bezel would be greatly appreciated, it really hits the mark. Thanks ... I didn't took pics while making the bezel but I can ain the method, which is sort of basic.For the bezel ring I've modified a spare one that was on my drawers and whose exterior diameter fitted the watch ... I've just sanded the inside diameter until it can turn easily around the plexi, with a gap of about 1/4mm ... so you just have to work slowly as if you go to far then the bezel ring is loose ...For the paperclip spring is used ... a paperclip ... I just sanded it to make it thinner so that it can fit to the inner groove of the bezel ring ...The "printing" and "applying" is the only tricky part ...I first drew the design on Illustrator at 2400ppi then up to 4000ppi on Photoshop ... it took me hours as I didn't found any font matching the original one so I had to design every letter and number ... one by one ...Then I printed the design, reversed, on sunnyscopa film-free decal paper ... I first made many test on glossy photo paper to get the "right" red colour ... of course I've used a laser printer as film-free decals need toner and not ink ...Then I applied the decal on the prepared bezel (sanded 2000 grit) ...You have to gain some experience to achieve that :- Glue and applying : Let the glue cure too much and you can't positionate the decal properly ... let it cure not enough and the decal slips while heating ... when properly applied you need let that cure about 5 mns, remove all bubbles, then let cure again about 1/4 hour before heating ...- Heating : Heat too much or to closely and the film will shrink ... not enough and the toner won't adhere to the metal ... I heat with a hair dryer for about 2mns at medium heat, gently press to make the toner adhere, leat the metal cool, heat for 3mns again at high heat, gently press again, let the metal cool again then gently remove the film ... of course time and heating depends on the temperature in the room you work ...- Remove the film :Tat's when you know if you worked properly, or not, while going and and heating and there's no way back ... If the result is bad you just have to remove the toner with nail varnish remover and start everything again ...If the result is OK you wash the bezel with cold water to remove all the remains of glue ... you can rub with your fingers as the toner is already hard ...Then you heat again at high heat for about 5mns to make the toner melt again and when cooled it becomes incredibly scratchproof ... really amazing how hard it becomes ...You also can do the last heating in a kitchen oven but some metal becomes yellowish if heated too much so you have to take care to heat less than 180/200°C ... and if there is any glue remaining it will become yellow too ...So all that's why I wrote about gaining experience ... when I begun using film-free decal papers the score was 10 trials/1 success ... now it's about 2/1 only ... 1 Quote
Watchtime Posted June 1, 2020 Posted June 1, 2020 Very nice....looks like a Vostak Amphibiacase... Quote
JTwinney Posted June 1, 2020 Posted June 1, 2020 The watch itself is Waltham USA and the case is Philadelphia watch co. But that is pretty much all I know! Quote
manodeoro Posted June 1, 2020 Author Posted June 1, 2020 The watch itself is Waltham USA and the case is Philadelphia watch co. But that is pretty much all I know! which watch ? Quote
Harleydee Posted August 2, 2023 Posted August 2, 2023 Hi Manodeoro, Great Job ! Your post has motivated me to have my watch, which is identical to yours, profesionally restored. Mine was a 18th birthday gift in 1972. I can not remember what the original watch strap looked like as it had a wide leather one since the late 70s. Is the steel strap you have used the original style ? saying that, yours may be different if its a 1977 watch, I have written to Ingersoll but had not reply. Many Thanks. Quote
