Having trouble with a serviced AS 1882 . This watch is only making a lot of trouble . At first i bought it and it didn't work so very well . Tried to service it but it didn't go so well . Something wasn't right  . Could get the part together . So i bought a nice looking watch with the same movement cheap . That movement is now serviced and running strong . It works ok in the timegrapher . But the hands won't follow the movement . The hour and minute hands stops or is slow . But the second hand works and keeps ticking .  I will soon get an old movement that missing some parts .Which i have from the first movement . Going to get that movement serviced and see if i can get it to work in the other nice looking watch . What is the trouble with hands ?
Edited by rogart63
The cannon pinion is needing tightened. There are various tools available for doing this, have a look on EBay you should be able to pick one up cheap.
+1 for Geo's reply - I've had this problem with a number of movements over the years. Slow or wobbly and unpredictable movement in the minute hand - corrected by either tightening or replacing the cannon pinion.
Hi Rogart, I have become abit of an expert on the AS movements after purchasing a Mido with a similar problem, 3 movements later I got it working!. It is the small gear on the end of the Large driving gear that needs to be tightened. Its part number 201/1. The Canon pinion is driven from that along with the date change mechanism. Cousins have the parts list if you search for AS1882.
Actually suspected that  gear . What should i search for on Ebay ? Cannon pinion tighten tool ? .
Edited by rogart63
Canon pinion tool would do it there is one here in this lot , it is the tool in the top left hand corner of the box ebay item no 191502866512
Edited by Andyclient
I use a blunt pair of nail clippers, you can guess why I use a blunt set!!..find a drill bit or equivalent (think its 0.65mm for that gear) and gently squeeze. It actually quite simple if you take your time.
Here's mine, it's a set of wire cutters that I have drilled and tapped to accept a screw to limit the amount of squeeze that you give the pinion.
If you go this route it is easy to make very small adjustments at a time until you get the correct fit. It can be done without using a drill or a mandrel in the pinion if you are very careful, but it is a lot safer to use one. Remember, this is a trial and error fitting exercise to get the best fit.
  • Like 5
Naaw i need to get the whole movement apart again . I suppose i will need to support the other side when i press the cannon pinion on the large gear again . Or would it work to support only jewel where the axle sits ?
Provided you don't make the pinion too tight, it should just snap in place with the rest of the movement assembled.
I will try it when i got the other movement . Have a blunt nail clipper so i will try that first . Good to learn something today . Thanks
Please find attached pic of the tool I have used a few times picked it up a few years ago on eBay with other tools.  I think its a hand made job but works treat.
Edited by clockboy
If you have a staking set there should be a stake or a stump that would work.    BE VERY CAREFUL NOT TO OVER DO IT.   broaching the whole out after it has been dimpled too much is a real pain.   Personally I would use the staking set or an actual cannon pinion tightening tool   that in like a mini staking set.  I don’t like the clipper type if the cannon pinion is thin as in the offset cannon pinion type is. It is very easy to destroy it by over-tightening it.    I have attached a photo of the one I use
Sincerely,
Jim
Just to make sure i do the right pinion i took a picture of it on non working spare part movement i had  . Could take that pinion if it's nice and tight too . The one to the right is the cannon pinion ?
I prefer using the cutter style tightener, same as geo's. I find you get the most control and it is nearly impossible to fudge it. I still slide the CP down an old oiler first, but the screw on the cutters make it impossible to crush the CP in any case.
I will defer to you here Mark   putting the CP over an old oiler is brilliant  thank you.    The thin offset ones have always given me trouble.  I have over done a few  :-(
Thanks again for the post
Jim
Have fix the cannon pinion and it has been ticking with some odd hands i had in a box . Just to see if it works ok . Now i can put the datewheel and date mechanism back again . Had to do it a few times and had to support  the wheel from the other side when i pushed it on . Looks a little strange with hands .It's 8 a´ clock
Have one more to go :pulling-hair-out: . Got a repair movement today in the mail . Learn by my mistakes so hopefully it will go much better this time .
    • Hi folks, I'm doing some homework on getting a watchmaker's lathe, and it's clear I have a lot to learn. But I know one goal: I want to be able to fabricate wheels, which would require an indexing capability. I know how to use large lathes- like, giant metal lathes- but my experience is a few decades old now (but you never forget the smell of the metal cutting oil). So I'm looking to learn anew, and have a goal to get to a point where I can fabricate some basic watch parts. I also have no specific timeframe and want to do this right, so I'll be patient and learn what I need to before spending the money. I know I'm not going to get anything for a pittance, but I'm also not really able to put together the scratch for a $5-$10k lathe. What's out there for a hobbyist that can either handle some fabrication out of the box or can be relatively easily made to do so? Thanks!
    • Hello and welcome to the WRT forum.   This usually points to broken balance pivot.  Though a watch in need of clean & lube can do the same. Easiest diag would be to  see if balance pivot doesn't stay in hole jewel of the setting, when you lift one side of balance rim with an oiler or gently with pair of tweezers. Another would be to detach balance complete from the cock and take a look at pivot under high maginfication.  Regs
    • Ahhh, yes.  I hadn’t thought of that.  I’ve serviced quite a few of these and the first time I didn’t realise it was a ships strike pattern!  Ha ha, confused me totally until I realised.
    • Hi Mike, I did, thanks. Found this clip that was really helpful:   It says Seth Thomas but it's actually the same Hermle I've been working on. I'd had it working correctly all along but hadn't noticed that the lever with the sprung end stops the hammer a bit short of the bell on the second ding at the end of the half-past sequence. If only I'd put the bell on when testing, rather than just looking at the hammer, my ears would have told me it was working,  even if my eyes didn't!
