Hi watch and clockmakers,
May I ask for your thoughts about the glue shall be used to fix the crown to the stem? I did my initial research and many mentions loctite, but i found none of the ppl who actually said which loctite. When it was mentioned on this forum loctite 638 it was also stated that probably not ideal. Even in Mark's video loctite was just mentioned as loctite. Is it obvious as which one? As far as I understand it has to be strong enough so the crown would not come off and weak enough to be able to remove the crown? I guess the latter only matters with special crowns not the ones you can buy for 10p, or when you cannot easily replace the stem/crown with vintage watches as they are not available for purchase? Would this one do? loctite I guess many would use something else than loctite.
Take care and my bestregards,
Lui
May I ask for your thoughts about the glue shall be used to fix the crown to the stem? I did my initial research and many mentions loctite, but i found none of the ppl who actually said which loctite. When it was mentioned on this forum loctite 638 it was also stated that probably not ideal. Even in Mark's video loctite was just mentioned as loctite. Is it obvious as which one? As far as I understand it has to be strong enough so the crown would not come off and weak enough to be able to remove the crown? I guess the latter only matters with special crowns not the ones you can buy for 10p, or when you cannot easily replace the stem/crown with vintage watches as they are not available for purchase? Would this one do? : loctite I guess many would use something else than loctite.
Lui
I use no loctite for pocket watch crowns and stems as the threads are big enough to have a good grip. For watches, the blue medium should do. Any other thoughts out there?
Loctite blue seems to be the most favourite by watch repairers. I never ever used any type of glue. If the button came away from the stem, it would be the inside thread in the button had worn, or some wear to the thread of the stem or both. So I would replace, what ever was needed.
I personally have had good experiences with the purple Loctite 222.  Its described as low adhesive and for fasteners that require occasional adjustment so its easy to loosen if all of a sudden the crown would need to be removed.
Yeah that's what I have and indeed is weak so to suggest that faith is also required for it to hold.
I use 243 which is fairly weak. However, I picked up a pritt-stick style Loctite which is much easier to apply than the liquid, so will start trying that.
When I can't put my hands on the 222 I use 243 hahaha. Just don't use 638/648, you'll need a torch to get it loose.
(Going off topic slightly, but I’ll post this while I remember): Someone asked me yesterday which was the BHI-recommended Loctite for securing clock wheel collets to arbors which is 603 (this is when not soldering).
  • 4 years later...
I've just tried using some red threadlocker labelled 271 (not loctite) for the first time to secure a replacement pin (opposite the existing boot) & was surprised to find that it hadn't set after 36 hours. I'm wondering if I've not applied it correctly or if the stuff I've got is of poor quality (the blue version, 243, seems ok though).
Threadlockers belong to a class of adhesives called anaerobic adhesives. They are resins that polymerize and harden in the absence of oxygen.
That's why the stuff remains liquid in the bottle but can sometimes set in the narrow tip of the applicator where the surface exposed to air is minimal.
You can test to see if your bottle is ok by applying some to the threads of a clean bolt and screwing on the nut. It should start to harden in about an hour or less. But only the stuff deep in the threads will set, the excess that is squeezed out to the surface will remain wet and tacky.
Heat also speeds up the set of anaerobic glues. If you are using it in arctic conditions, an accelerator is required.
Thanks for the education, Hector. Clearly, the problem was my ignorance not the red threadlocker!
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
