Hi
Quite new to this and looking for some help and pointers
After successfully repairing a Jerome Clock (which now runs a treat) I have got hold of a Longcase Clock Movement, 8 Day C1760, Jos Vale, Walsall
I have mounted it in the case and now need 3 things (I think)
  • A bell as that’s missing
  • A pendulum - really need help here as there seem to be so many variety’s around
  • Weights - research suggest that many of these older movements require 3 weights, mine clearly needs just the 2 but what weight the weight should be I have no idea
I have added some pics
Is there anywhere online I can see how the weights attach ?
Thanks in advance
Regards
John B
You can pick up a bell from ebay, loads of them about, the same with the pendulum about a 4 inch, the same with the weights around 12lb as you say you need two. I’m enclosing a photo how they are attached, you need two weight hooks these you can get from any good clock/watch material suppliers. If you wanted you could get it all from a supplier, I do not advise this as it will not fit in with the clock. The clock dial has a part missing, do you have the part?
thanks, very helpful
I do have the missing part so its complete, I have found weights and a bell and weight hooks. Im struggling with the pendulum I can find quite a variety It needs to fit through the crutch and up onto the bracket so needs to be quite long etc, i guess we should not mention suppliers on the forum but any pointers appreciated
Regards
John
At the top of this forum you will see Resources, click on that and you will see a list of countries, click which country you live in, you will then see a list of suppliers from that country, many on here use Cousins here in the UK.  You can mention suppliers if you want, no harm done. Don't for get the suspension spring for the pendulum. If you need more help just ask.
thanks I have contacted a supplier and they were helpful - pictures have been sent, so lets see what happens
On the front of the clock face plate it says jos vale, Walsall - a google of the name revealed nothing ?
Regards
John B
