Hello, I have a Seiko Sportura SNJ007.  It's a quartz I bought many years ago and enjoyed it until the battery died.  It costs almost half the price of the watch to get the batter replaced here so it just kind of sat in my drawer for a few years.
After researching a little I figured I could replace the battery myself.  I bought a cheapo watch repair kit on Amazon and following some directions online managed to replace the battery.
After putting it back together everything worked fine except for the seconds hand.  It seems to be stuck at 0.  The other two hands move fine and the digital stuff works fine too.  It's just the second hand.
Any advice would be greatly appreciated!
So the watch goes but the seconds hand doesn't move. Do you know if when you first had the battery replaced if the movement was removed from the case? Check to see if the hand is to close to the glass.
I replaced the battery myself.  I believe I did remove the movement from the case to replace the battery.  I will open it up again tonight and see if the hand moves while outside the case.
Thanks for the idea!
Hello and welcome to the forum,, as Old Hippy suggests the second hand may be bent and catching the glass  easy done when handling a movement, hence the use of movement holders.
So I just took out the movement and removed the battery and put it back in.  Even out of the casing the seconds hand still doesn't move.  Looking as close as I can at the hand it doesn't look bent or dislodged.
Do you guys thing a line release would help.  I am not really sure what it is but I have seen in mentioned a few times for fixing stuck quartz movements.
Hi    There is a complete reset , pull out the crown 2 clicks and press and hold the upper and lower buttons for 6seconds and the watch should restart if there is no damage.
Hello watchweasol, This model doesn't have a crown.  Here is the manual.
There is a reset function described in the manual.  Hold all four buttons at once.  I did that after each battery change.
    • Very interesting! I answered the mail from Longines, explaining that I was a bit disappointed and that I wouldn't ask for a costly confirmation for a watch which isn't a high-end one ... and I received another email explaining that they couldn't not certify the authenticity of the watch, but they could specify that, according to the serial number on the caliber and to their handwritten records, the watch was produced in 1938. Great! @Mercurial I will take the measurements and will keep you informed. Thank you all. This forum is incredible 👍
    • Good stuff, thanks!!!  I'm going to save it and re-read your post and watch the video again.  I have a few follow-up question:  My understanding is that the spring vibrates or breathes between the the two regulator pins. When the pins are fully open the effective spring length is from the stud and theoretically no rate adjustment can be made by moving the regulator arm. As the pins are closed the spring gets closer to one side of the regulator block but doesn't touch a pin. You can still move the regulator carrier the entire terminal curve without upsetting the coils.  The rate can now be adjusted using the regulator because the effective spring length can be modified.  My question is: Does the hairspring bounce off and touch one of the pins as it breathes? Is that why the effective hairspring length is adjusted by moving the regulator?  And follow-up: How is amplitude affected by the spring between the pins? Does fully open pins, dial up position = max amplitude?  When spring adjusted to 1/2 width still = max amplitude? When I have crown down gravity is pulling the spring against one of the pins and I would expect rate to go up and amplitude to go down. Is that correct?
    • A quick Google for Longines 25.17 found several similar watches - like this one with writing on the case back similar to yours https://benjaminmarcello.nl/product/longines-cal-25-17-tank-from-1938/
    • Apps like Watch Accuracy Meter can be inaccurate, and will read some watches better than others.  What daily rate does Watch Accuracy Meter give you if you check the Longines once it’s been running for 24 hours? Best Regards, Mark
