Hey
How do I get the spring back in the collet?
Can it be done?
And if yes what tools do I need or is it just putting the V shaped notch in the spring into the gap in the collet.
Cheers
Gary
Hi Gary   the whole spring looks in bad shape and the inner coil looks to be facing the wrong way for it to be re fitted. So the priority is to get the spring back into shape and once done then approach the fitting to the collet.
Yer I know the spring is in bad shape.
So thought good time to find out how to reattach it as this is the 3rd one I have done this to.
Inner part of spring is the way it came off not twisted.
I presume I try to insert the pointy part of the V into that gap in the collet.
But I do not know how.
Cheers
Gary
There's a hole in the collet, and the spring was held in by a tapered pin. The pin needs to be pushed out, the old piece of spring as well, and the spring bent and refitted to the collet, either with the old pin or a new one that gets trimmed to length after fitting without damaging the spring (this is how it's done). All that done you're now "that much shorter" and it doesn't look like you have any extra spring at the stud to let out, so if a balance with screws you'll need to add a fair few timing washers or your 18000 bph watch is now like some of the old Lecoultres beating at 20222.
the procedure looks pretty simple on paper doesn't it? I will attach a few pictures to get you started..  Then as somebody else pointed out  you're going to lose quite a bit just doing this even if you did it perfect the first time you'll probably never be able to regulate this watch ever again. on the other hand it looks like you need to get some hairspring practice this will give me some practice time because  a lot of hairsprings cannot be replaced..
tthen you still website that was much better on this that seems to have disappeared? But in the meantime I did a search I found you a few supply places and some other people playing with hairsprings all of this will get you started..
https://www.cousinsuk.com/category/hairspring-collets-pins-studs-boots
http://www.scotchwatch.com/Hairsprings.html
https://watchmakingjourney.com/2014/08/16/last-week-final-project-colleting-and-studding-hairsprings/
http://zzmiller.blogspot.com/2013/10/this-week-ive-been-working-on-forming.html
http://www.geocities.ws/dushang2000/Bench Tools and Accessories.html
    • Good stuff, thanks!!!  I'm going to save it and re-read your post and watch the video again.  I have a few follow-up question:  My understanding is that the spring vibrates or breathes between the the two regulator pins. When the pins are fully open the effective spring length is from the stud and theoretically no rate adjustment can be made by moving the regulator arm. As the pins are closed the spring gets closer to one side of the regulator block but doesn't touch a pin. You can still move the regulator carrier the entire terminal curve without upsetting the coils.  The rate can now be adjusted using the regulator because the effective spring length can be modified.  My question is: Does the hairspring bounce off and touch one of the pins as it breathes? Is that why the effective hairspring length is adjusted by moving the regulator?  And follow-up: How is amplitude affected by the spring between the pins? Does fully open pins, dial up position = max amplitude?  When spring adjusted to 1/2 width still = max amplitude? When I have crown down gravity is pulling the spring against one of the pins and I would expect rate to go up and amplitude to go down. Is that correct?
    • A quick Google for Longines 25.17 found several similar watches - like this one with writing on the case back similar to yours https://benjaminmarcello.nl/product/longines-cal-25-17-tank-from-1938/
    • Apps like Watch Accuracy Meter can be inaccurate, and will read some watches better than others.  What daily rate does Watch Accuracy Meter give you if you check the Longines once it’s been running for 24 hours? Best Regards, Mark
    • Then, can I replace it by purchasing a regular ruby with the same or similar width and height and pivot groove size from eBay? If I replace it like the above and operate the movement, will there be no problem?
