Hi    The fitting of a shim is NOT a fix its a diagnostic aid in as much as to slightly increase the end shake of the balance when trying to determine the problem, and once proved on way or the other, then removed and look to rectifying the problem.   I have had watches where the end shake was adjusted by digging a divot in the plate there fore raising the the balance cock and increasing the endshake also had them with shims in to do the same both left as a permanent fix    Not reccomended.
Okay !
Okay !
7 hours ago, jdm said:
Absolutely. I was surprised to see that this kind of advice given promptly when the practice is generally frowned upon.
Thanks for all the help Jdm, that was just a temporary fix until OP finds the broken pivot. We need advise how to weld it back on.
  • Confused 1
Well looks like a broken pivot as we can all see, you must have not seated the balance properly before screwing it down which is why it doesn’t look even which was pointed out by John...which is was what I thought to begin with.
One of the problems with your watch is it has a balance jewel protection system. This means the likelihood of you breaking the pivot  through normal use is nearly impossible. But for reassembly  it's a problem in that you have to get the balance pivots through  a relatively tiny hole. the lower one  usually isn't a problem it's the upper one where it's easy to get it off to the side  it might even still spin to some degree but tightening  the bridge screw down  very bad if it's not where it's supposed to be.. I thought for the future  just remove the entire upper jewel assembly which are going to have to do to lubricated anyway. Then you can see that your pivot is where it's supposed to be  before you tighten the bridge screw down..
Ok thank you very much, I haven't made it yet but i'm going to try this without making a mess (like loosing the thing on the jewel of the cock) :)
    • Good stuff, thanks!!!  I'm going to save it and re-read your post and watch the video again.  I have a few follow-up question:  My understanding is that the spring vibrates or breathes between the the two regulator pins. When the pins are fully open the effective spring length is from the stud and theoretically no rate adjustment can be made by moving the regulator arm. As the pins are closed the spring gets closer to one side of the regulator block but doesn't touch a pin. You can still move the regulator carrier the entire terminal curve without upsetting the coils.  The rate can now be adjusted using the regulator because the effective spring length can be modified.  My question is: Does the hairspring bounce off and touch one of the pins as it breathes? Is that why the effective hairspring length is adjusted by moving the regulator?  And follow-up: How is amplitude affected by the spring between the pins? Does fully open pins, dial up position = max amplitude?  When spring adjusted to 1/2 width still = max amplitude? When I have crown down gravity is pulling the spring against one of the pins and I would expect rate to go up and amplitude to go down. Is that correct?
    • A quick Google for Longines 25.17 found several similar watches - like this one with writing on the case back similar to yours https://benjaminmarcello.nl/product/longines-cal-25-17-tank-from-1938/
    • Apps like Watch Accuracy Meter can be inaccurate, and will read some watches better than others.  What daily rate does Watch Accuracy Meter give you if you check the Longines once it’s been running for 24 hours? Best Regards, Mark
    • Then, can I replace it by purchasing a regular ruby with the same or similar width and height and pivot groove size from eBay? If I replace it like the above and operate the movement, will there be no problem?
