Hello Everyone,
I'm looking forward to getting acquainted with you all as I dive into watchmaking and collecting again after a little hiatus of a couple of years. For those who saw my introduction post, I am a keen russian watch collector and I'm tinkering with watchmaking after having done a couple of online courses several years ago.
I have in my collection a Poljot watch with a 2409 movement. It wasn't ticking and to be honest I can't remember if I bought it that way or not. Anyway, with all this extra time on my hands at the moment, I've been watching a lot of WR videos and it has reignited my passion for watch repairs.
I took the 2409 apart and gave it a good service. I have the watch back together and as soon as I inserted the balance the watch started ticking again. Great! It ticked for about 40seconds or so with some noticeable missed click and then stopped. Interestingly, I noticed that the pressing down on the barrel bridge got the watch ticking again. I though perhaps i didn't tighten the screws down properly so I tried resetting the barrel bridge and barrel and still the same problem. I have a several spare parts movement so I tried using a different mainspring barrel thinking perhaps there was something wrong with the mainspring? That made it work a little longer (2 minutes or so) but still the problem persisted and pressing gently down on the barrel bridge kick started the watch again.
I'm going to strip down the watch completely and inspect every part more closely for any sign of defects. Any ideas what may be going on here? Where should i focus my attention?
Thanks again and I look forward to participating in this community.
Thank you NuceJoe, I will keep that in mind, but at this stage I've yet to install the minute wheel.
Watchweasol, thank you so much for that PDF, it really is great. That makes a lot of sense. I changed the whole barrel assembly including the arbour when I swapped out the mainspring. It did work better so perhaps the spare movement also had a problem(not sure of its history). I'll take a close look under a microscope if full light tomorrow morning and report what i see.
Thanks, you've been so helpful already. I'm glad I found this site.
I would look at the leaves of the center wheel pinion. Could be a small piece of dirt that could cause it to stop. Clean all the pinion leaves carefully.
CHeck that the barrel does not tilt when installed. If it does the holes in the barrel bridge or mainplate could be worn slightly, that is why it works when you press down the barrel bridge.
Anilv
Thanks so much for all the great advice.
@anilv I think you may have hit bingo with this comment " barrel bridge or mainplate could be worn slightly, that is why it works when you press down the barrel bridge."
I did notice the mainplate had almost a rut scratched into one area, and I guess subconsciously that's what made me press on the barrel bridge suspecting something might have been amiss here. I have a spare mainplate so I will try that one and see how it performs. Any ideas what would cause that amount of wear? I guess poor servicing history?
Thanks JDRichard, I will take a close look at that as well.
probably wear and tear. Problem with russian watches is that while the movements are good, the cases are pathetic, offering little in the way of protecton from humidity and dust. Hence they require regular servicing.
Anilv
Thanks again Anilv, I agree. I watched a video the other day of someone restoring an old omega seamaster. It looked like that watch had been rolling around in someone's toolkit for years. I was surprised to see how well the case did it's job because the dial and movement where in amazing condition. I remembered thinking that would not be the outcome if that watch had been in a Raketa or Pobeda case. Having said that, I do like the Vostok Amphibia case design, I find those to be very well engineered for diving.
Just to pass more credit where it’s due: then third comment from WW suggests checking the barrel arbor bearings as these cause tilt due to side-shake.
    • I own too many WW lathes, as well as two sherline lathes and a sherline mill with a cnc indexing rotary table. The majority of my experience is using the WW lathes to make staffs, screws, and stems. Recently, I have been experimenting making a pinion on the mill using the indexing table. It works. So, if you want to cut wheels, get the Sherline mill and indexing table...imho
    • That's strange. I re-serviced a couple of watches after about 4-5 years and there looked to be no loss of oil. These are watches I very rarely wear, and I probably over-oiled a bit back then.
    • That's nice! Cousins do know how to make money in a way that benefits themselves and their customers. Repairing wouldn't be the same w/o them. For most purposes, 10ml goes a long way. However, with a few exceptions, I’ve started applying Fixodrop to all parts that come into contact with grease or oil, so I went ahead and got the 100ml bottle. I just serviced a watch that I last worked on seven years ago, and to my surprise, it was practically dry—almost no oil left. I suppose it either evaporates or migrates over time? I just now browsed the available options and noticed that Fixodrop 8981 ES/BS-10 (Ready to Use) is a bargain at just £104 per 100ml. Well, that is, compared to Fixodrop 8982 ES/BS-20 (Ready to Use), which goes for £850 per 100ml. According to ChatGPT, 8981 is intended for inexpensive watches serviced by enthusiasts, while 8982 is geared toward high-end timepieces handled by professionals. Or could it be that Moebius found a way to squeeze more money out of the same product? Hmm...
    • Often times the belief is when you're making small parts you Need a small lathe like a watchmaker's lathe to make small parts. But for gear cutting its oftentimes better to have something bigger. Then realistically you might end up with several things not just one machine for everything. Depends upon your machining skills and the equipment you have. This is where having a slightly bigger equipment allows you to make all kinds of things where if you have a tiny equipment you can not really make bigger stuff it's very awkward. Then indexing is all kinds of ways to do indexing a very popular way is with the stepping motor a worm gear like at the link below https://www.ebay.com/itm/191714031261 What's interesting with something like this is you can micro step at end up with basically a infinite quantity of indexing. But you still have to build some things. For instance here's an interesting YouTube channel and an interesting video. His watchmaker's lathe is a little bigger than what I'm typically used to for watchmakers lathe. As a rather interesting cross slide and notice he makes just about everything. Then he gets the indexing something purchased surplus but it's basically just a worm gear stepping motor his has way more hands-on control but it does the exact same thing as the one up above. Then if you read the description of the video is in a shop of creative people to build all kinds of nifty things like the stepper motor controller etc.
    • Yes they are a silly price. Fortunately the 10ml Moebius bottle has a metal gauze in the top, so no need for a separate bottle. They shouldn't be!  Mad idea. I changed them for coloured ones
