Hey guys! I just broght a Universal Geneve watch with cal 1-42 movement. The dial is amazing and the price is very low so I dont even hesitate to buy it. But the buyer did notice me that the MS is broken so I need to replace one. Unfortunatly the original MS is out of stock, I can not find a original replacement. So I'm thinking about buying an alternative one.
I haven't receive the package but I dig some research so these are what I know now:
width of the MS: 0.9mm
Thickness: 0.10mm
Inner barrel diameter: 8mm
Length: unknown
It will be very helpful if you can help me find an alternative. I dont have a GR book so I dont even know where to start.
Thank you guys!
44 minutes ago, nickelsilver said:
Generale Ressorts lists a 0.90x 0.10x 260  8 spring, which happens to be for their replacement for Movado 245 and Universal 820. Should work fine.
Thanks. But these two are not so easily accessable as well:(
NS has identified the approximate length you need. It is not critical. Just get the closest length you can.
If you are UK-based then I can take a look through my sets if you can’t find something from Cousins.
Hi. May I ask how can I know what movement use the particular size of that mainspring? Where can I get those informations? thank you !
GR catalog can be downloaded on Cousin's, click "documents" on any mainspring page.
On 6/25/2020 at 7:19 AM, EatPeach said:
Just checking if cousins can ship to my country.
Cousins ships to any country. In another topic you wrote that shipping to your one cost too much, I'm surprised by that since under ₤25 they can ship untracked at actual cost. I pay GPB 2.20 to EU, I assume it's just a little more for the Americas or the rest of the world.
I live in China so an untracked post is definitely not an option, your package will be lost in China for sure! I need three MS because I got 3 universal 42 suffering the same problem... And the cost of the shipping is €20. If unfortunately I get taxed in China I will pay €5~10. I'm still a postgraduate so I'm buying on a budget. That's why I'm considering other cheaper alternatives. If that's OK it will be a big relive because you don't know how frustrated shopping worldwide in China.
Edited by EatPeach
1 minute ago, EatPeach said:
I live in China so untracked post is definetly not an option, your package you lost in China for sure!
Find a friend or service to reship to you from the UK or other reliable country. I know that "proxy buyers" are popular, shopping on behalf of others, then smartly packaging and declaring goods to China.
Thanks for the advice. I will consider your proposal if it's available.:)
    • That's strange. I re-serviced a couple of watches after about 4-5 years and there looked to be no loss of oil. These are watches I very rarely wear, and I probably over-oiled a bit back then.
    • That's nice! Cousins do know how to make money in a way that benefits themselves and their customers. Repairing wouldn't be the same w/o them. For most purposes, 10ml goes a long way. However, with a few exceptions, I’ve started applying Fixodrop to all parts that come into contact with grease or oil, so I went ahead and got the 100ml bottle. I just serviced a watch that I last worked on seven years ago, and to my surprise, it was practically dry—almost no oil left. I suppose it either evaporates or migrates over time? I just now browsed the available options and noticed that Fixodrop 8981 ES/BS-10 (Ready to Use) is a bargain at just £104 per 100ml. Well, that is, compared to Fixodrop 8982 ES/BS-20 (Ready to Use), which goes for £850 per 100ml. According to ChatGPT, 8981 is intended for inexpensive watches serviced by enthusiasts, while 8982 is geared toward high-end timepieces handled by professionals. Or could it be that Moebius found a way to squeeze more money out of the same product? Hmm...
    • Often times the belief is when you're making small parts you Need a small lathe like a watchmaker's lathe to make small parts. But for gear cutting its oftentimes better to have something bigger. Then realistically you might end up with several things not just one machine for everything. Depends upon your machining skills and the equipment you have. This is where having a slightly bigger equipment allows you to make all kinds of things where if you have a tiny equipment you can not really make bigger stuff it's very awkward. Then indexing is all kinds of ways to do indexing a very popular way is with the stepping motor a worm gear like at the link below https://www.ebay.com/itm/191714031261 What's interesting with something like this is you can micro step at end up with basically a infinite quantity of indexing. But you still have to build some things. For instance here's an interesting YouTube channel and an interesting video. His watchmaker's lathe is a little bigger than what I'm typically used to for watchmakers lathe. As a rather interesting cross slide and notice he makes just about everything. Then he gets the indexing something purchased surplus but it's basically just a worm gear stepping motor his has way more hands-on control but it does the exact same thing as the one up above. Then if you read the description of the video is in a shop of creative people to build all kinds of nifty things like the stepper motor controller etc.
    • Yes they are a silly price. Fortunately the 10ml Moebius bottle has a metal gauze in the top, so no need for a separate bottle. They shouldn't be!  Mad idea. I changed them for coloured ones
    • There were colourless cap jewels on an oris 581 KIF I was looking at. I was convinced I’d lost them when I put the jewel into heptane and couldn’t find the caps. I didn’t know colourless ones were a thing!
