Cleaning a Watch Movement
Hi fellow watch enthusiasts, I hope you are keeping safe & well.
Having tinkered for a while, and completed the second of Mark's on-line course, I'm taking the plunge and undertaking a full dismantle, clean and reassemble of an old 1960's Tissot Seastar.  As a result I have two questions, if I may.
I read somewhere, that I should not subject the pallet fork to the harsh cleaning fluids, as it may damage the delicate End Stones.  Is this accurate and correct and are there any other components that I should not put in the harsh cleaning fluid..?
In addition, I've managed to secure a NOS replacement main spring.  I'm assuming that as its been sitting around for a good while it will need lubricating.  It there a method of lubricating the main spring without the need to unfurl it from the temporary housing it comes in, or once inserted into the barrel..?
Many thanks
Phil
Hi   welcome to the forum.    Cleaning  fluids and the methods are varied as are many opinions as to what to use and how but normally the use of Naptha , Benzine,  and rinsed in Isopropyl alcohol, for the hobbyist works. do not leave any part to soak if required clean it twice.  2 to 3 min in the ultrasonic per session and repeat as required is better than soaking.
Mainsprings need no lubrication. If it's an automatic you can place some anti braking on the barrel wall, and always HP-1300 on the arbor where it contacts other parts. Please search this forum using the box top right for the abundant discussions on the subject.
2 hours ago, Nucejoe said:
Chemicals do disolve the shalac, never heard any damaging the stones.
Not all chemicals do, as mentioned may many times benzine (and any petroleoum derivatives) do not dissolve shellac, and even IPA only does slowly. Of course, jewels themselves are resistant to pretty much anything.
Edited by jdm
Thanks for the advice, really useful...
Thanks for the advice Watchweasol, really appreciated.  Fully understand the not leaving to soak for too long bit, having read a post on here just yesterday, about the damage that can be done...Thanks again Phil..
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
