Thanks Geo for the link . I found one incablock spring on an other movement and now have it  up and working nice . Only the date mechanism to assemble . Lost a click spring but found it some hours later .
Edited by rogart63
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
