In 1999 a friend came from Russia to stay with me for a week to attend a cell biology conference in my city. As a gift, she brought me a clock out of a MIG fighter. It stopped working and I opened it to see if I could find out what was wrong. I found that the jewel that holds one end of the balance wheel had broken. I had no idea how to find a new jewel for it or if it was even possible. I also didn't want to go taking the whole thing apart for fear of never being able to put it together again. Does anyone have an idea who, in the US, might be able to do this?
Thanks,
Mike
Thanks,
Mike
Assuming his was a cold war MIG then the clock, if luminous, probably used radio active material to achieve the luminescence, the dust from which is VERY dangerous if inhaled. Great care needs to be used when opening luminous clocks and watches from the1960's and before.............
That's very interesting. I'm very much into Russian wrist watches but have never worked on any Russian clock. I know Vostok makes ship clocks available to anyone interested. Not sure new members can upload pictures but that would be a good and interesting start.
Is it one like the one below? That one is mine. Parts are difficult. You can get a new balance wheel or a set of hands, or a dial, even a nice display stand, easier than any other bits. Is it the jewel in the balance bridge? If so, you may find it easier but not financially feasible to purchase an entire watch and possibly scavenge the balance, though it would be a waste of one watch for another. I put in a question with a seller on eBay who is selling a handful of miscellaneous gears for one of these to see if they have a bridge available, assuming that is the culprit. Mine has an issue with the lower balance jewel Chaton. It had moved away from it's propper position and would cause the balance to overbank randomly. I seem to have it sorted now. They were built in a relatively robust manner, most bits are quite easy to disassemble. I suspect the reason there are so many available is likely because it was easier to replace a faulty watch rather than try to service one. Most were likely sent back to the factory but again, it was just simpler to ship out a new one rather than to bother fixing them. These watches were in military aircraft so they were certainly subject to vibration, impacts, shocks, and wild temperature swings to say the least. I would imagine it wouldn't take long before issues began to arise. The were usually placed low in the instrument panels to make getting at them easier when they failed. 2 thumb screws and two wire connectors were all that were required to remove these. As I said, mine is running reliably now as long as I don't fiddle with it too much while it's running. I would be curious to see photos of yours. I'll let you know if the eBay seller gets back to me.
My AChS-1 watch
There upper balance jewel.
Here is a shot of one properly mounted in a Mig-29 Fulcrum.
Edited by FLwatchguy73
FLwatchguy73,
Yes! Looks exactly like this. And last time I was in it to see it looks like the upper balance wheel jewel had broken. Oh well. Too bad to hear about parts. I figured as much though. Thanks for the answer.
-Mike
FLwatchguy73,
-Mike
you're in luck, the seller on eBay I messaged has a complete balance arm available.
quoted message below....
New message from: remwatch (650)
Hello.I have a balance bridge. But I also have jewel for it.
HERE is the link to the original listing. Contact the seller and see how much they want for the Bridge.
While is true that Radium is an hazardous tolerance, this routine warning given every-time that an old watch is mentioned is greatly exaggerated. The danger becomes real manly when the substance is ingested, or inhaled, and for prolonged time. Occasional manipulation of watches do not present danger whatsoever. Otherwise all of the old watchmakers and dial / hand manufacturers would be dead or fell sick back in the 60's already, fortunately is not so.
https://en.wikipedia.org/wiki/Radium#Hazards
Edited by jdm
Agree, but with degraded lume flaking off the danger is in breathing in the dust, hence the warning........
    • That's strange. I re-serviced a couple of watches after about 4-5 years and there looked to be no loss of oil. These are watches I very rarely wear, and I probably over-oiled a bit back then.
    • That's nice! Cousins do know how to make money in a way that benefits themselves and their customers. Repairing wouldn't be the same w/o them. For most purposes, 10ml goes a long way. However, with a few exceptions, I’ve started applying Fixodrop to all parts that come into contact with grease or oil, so I went ahead and got the 100ml bottle. I just serviced a watch that I last worked on seven years ago, and to my surprise, it was practically dry—almost no oil left. I suppose it either evaporates or migrates over time? I just now browsed the available options and noticed that Fixodrop 8981 ES/BS-10 (Ready to Use) is a bargain at just £104 per 100ml. Well, that is, compared to Fixodrop 8982 ES/BS-20 (Ready to Use), which goes for £850 per 100ml. According to ChatGPT, 8981 is intended for inexpensive watches serviced by enthusiasts, while 8982 is geared toward high-end timepieces handled by professionals. Or could it be that Moebius found a way to squeeze more money out of the same product? Hmm...
    • Often times the belief is when you're making small parts you Need a small lathe like a watchmaker's lathe to make small parts. But for gear cutting its oftentimes better to have something bigger. Then realistically you might end up with several things not just one machine for everything. Depends upon your machining skills and the equipment you have. This is where having a slightly bigger equipment allows you to make all kinds of things where if you have a tiny equipment you can not really make bigger stuff it's very awkward. Then indexing is all kinds of ways to do indexing a very popular way is with the stepping motor a worm gear like at the link below https://www.ebay.com/itm/191714031261 What's interesting with something like this is you can micro step at end up with basically a infinite quantity of indexing. But you still have to build some things. For instance here's an interesting YouTube channel and an interesting video. His watchmaker's lathe is a little bigger than what I'm typically used to for watchmakers lathe. As a rather interesting cross slide and notice he makes just about everything. Then he gets the indexing something purchased surplus but it's basically just a worm gear stepping motor his has way more hands-on control but it does the exact same thing as the one up above. Then if you read the description of the video is in a shop of creative people to build all kinds of nifty things like the stepper motor controller etc.
    • Yes they are a silly price. Fortunately the 10ml Moebius bottle has a metal gauze in the top, so no need for a separate bottle. They shouldn't be!  Mad idea. I changed them for coloured ones
    • There were colourless cap jewels on an oris 581 KIF I was looking at. I was convinced I’d lost them when I put the jewel into heptane and couldn’t find the caps. I didn’t know colourless ones were a thing!
