Hi  A jewel gauge  is probably the best    or a seitz jeweling set with gauge    expensive though.  or a tapered needle  mark an measure with the micormeter where it stopsf or a cheap way , not totaly accurate.
10 hours ago, Daniel123 said:
Hi, what do people advise for measuring a balance wheel hole?
If you are measuring jewels, you are also measuring pivots, so you should have a micrometer already. All you need then is a lathe to make your own gauge set.
