This vid shows making a balance using incredible high end machine skills. Only years of practice can achieve this level of skill.
I also wish I knew what the liquid is he uses to attach the piece to a wax chuck & how he centred the piece.
I have tried shellac but could not get the piece centred.
It's Krazy Glue Clockboy, you can buy it here :- http://www.transtools.co.uk/fixings-hardwares/sealants-and-adhesives/superglues-and-activators/instant-krazy-glue-no-run-gel-2ml?language=en&currency=GBP&kw=&fl=1000&ci=55581786001&network=pla&gclid=CIi4y_rK2cMCFRTMtAod810AIg
It will come away with a bit of heat afterwards, then clean with acectone.
Good vid by the way! :)
I don't think he did centre the piece when he glued it to the chuck. He positioned it as close to centre as possible by eye and then machined it true.
Later in the video he did "catch centre" using a graver to provide a guide for the drill.
De Carle touches on this in "Practical Watch Repairing" when he describes making a wax chuck for turning a balance staff.
Excellent video though, great to watch.
That was my thinking Marc.
I Clockboy, Geo is correct. The gue is a cyanoacrilate based glue. You can find it anywher and it have several names, depending from manufacture. Normally is "Super Glue" or "Super Bonder". Be carefull with your fingers!  :D
When I said "be carefull with your fingers" I mean don't glue yours fingers together or at one of the parts to fix. I had read some people that when manipulate this glue stuck both finguers and need to split them by cut or peeling the skin. Today, you can find a solution that dissolve this kind of glue (something like/near acetone) but I don't trust on it. The first rule to use this glue is: don't use in excess. Less than you need to glue the parts is much better than too much!
    • Hi folks, I'm doing some homework on getting a watchmaker's lathe, and it's clear I have a lot to learn. But I know one goal: I want to be able to fabricate wheels, which would require an indexing capability. I know how to use large lathes- like, giant metal lathes- but my experience is a few decades old now (but you never forget the smell of the metal cutting oil). So I'm looking to learn anew, and have a goal to get to a point where I can fabricate some basic watch parts. I also have no specific timeframe and want to do this right, so I'll be patient and learn what I need to before spending the money. I know I'm not going to get anything for a pittance, but I'm also not really able to put together the scratch for a $5-$10k lathe. What's out there for a hobbyist that can either handle some fabrication out of the box or can be relatively easily made to do so? Thanks!
    • Hello and welcome to the WRT forum.   This usually points to broken balance pivot.  Though a watch in need of clean & lube can do the same. Easiest diag would be to  see if balance pivot doesn't stay in hole jewel of the setting, when you lift one side of balance rim with an oiler or gently with pair of tweezers. Another would be to detach balance complete from the cock and take a look at pivot under high maginfication.  Regs
    • Ahhh, yes.  I hadn’t thought of that.  I’ve serviced quite a few of these and the first time I didn’t realise it was a ships strike pattern!  Ha ha, confused me totally until I realised.
    • Hi Mike, I did, thanks. Found this clip that was really helpful:   It says Seth Thomas but it's actually the same Hermle I've been working on. I'd had it working correctly all along but hadn't noticed that the lever with the sprung end stops the hammer a bit short of the bell on the second ding at the end of the half-past sequence. If only I'd put the bell on when testing, rather than just looking at the hammer, my ears would have told me it was working,  even if my eyes didn't!
