OK Rob you wind, I mean win!
A built in anemometer could be handy if your flying a Tiger Moth and the pitot got blocked, but at £37132, I'll have to pass. It's just a we bit dearer than the lighter watch that costs £3.73 delivered from China. :)
No longer one has to pretend to light up his cigarette from ones watch, cursing Q for his geeky gadgets.
When all you need is a lighter in a watch, look no further...
Edited by Denis
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
